Question about Sewing Machines
I no longer have a manual and want to sew tonight. the needle will go in to the bobbin case if i push the wheel backwards but the wheel will not go forward if the bobbin case is in place. i have taken out the bobbin parts twice. i think i have them in correctly.
    Genius:
  • 1,788 Answers
You didn't say what kind or model of machine that you have, if it is Singer go to www.singerco.com and you usually can download a manual for free. If, it is a Brother go to www.brother-usa.com and download one from there. No one can help if they do not know the information.
Posted on Nov 15, 2010
Needle wont go into bobbin
Never EVER turn your wheel backwards... that causes it to go out of time. Take your machine in for Timing.
Nov 30, 2012 | Singer Sewing Machines
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
Needle will not move; the bobbin shaft is in the
Force the balance wheel backwards, you may have thread stuck round the raceway
Jul 04, 2010 | Brother XL-3510 Mechanical Sewing Machine
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
While sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Feb 05, 2009 | Brother CS-6000
Hand wheel will turn backwards, but not forward
here is some troubleshooting
Download your manual.
manual
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
Ok I know that youve checked this, but I have to ask.
Pg 39
Check and make sure the reverse lever isnt engaged.
I'm looking at pg 27 and see you have a traditional bobbin casing (not a drop in) make sure your bobbin is wound well and the case is inserted correctly. (they are picky)
Change your needle make sure its in right and tight. (I have bent many a needle just slightly, and it causes huge issues with this particular type of bobbin casing)
Pg 35 gives a test for the bobbin tension. If your thread rolls, the tension is too loose, OR the case may have gotten damaged.
Lets see if this helped.
Good luck
Jan 27, 2009 | Singer 3116 Simple
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
