Question about VillaWare 2010 Waffle Maker
Where can I get heat resistance wire for inside a waffle iron?
2 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: waffle iron top not heating
I don't know for your model type, but in many of these the heating element can be replaced. Check with an ohm meter to know if the element is actually defective, or if it is the thermo safety cutoff fuse that is blown.
If you were to do this yourself, and you know about appliance servicing, have instruments to check for proper temperature and current draw, and you will need the proper crimp-fittings (stake-ons), and crimp tool to do any of the wiring inside.
Jerry G.
Posted on Jun 27, 2008
Not get hot
Check the fuse or breaker. If they are OK, you need a new one. Small home consumer appliances like a waffle iron are not repairable.
Jun 16, 2016 | Kitchen Appliances - Others
Waffle iron light goes on gut does not heat up
The most common reason for not heating up is because of a blown thermal fuse. Apparently the controller lets the iron get too hot or the fuse is out of manufacturing tolerance - and so the fuse opens.
The green lamp is normally lit when the relay is off and dark when the relay is on. When cold, the relay normally turns on within a second of power-up (switched on). During power-up, the green (ready) lamp should flicker on, and then as the relay clicks, go dark. If the green (ready) lamp does not flicker, the fuse is probably blown.
The fuse is clamped inside the bottom clamshell in silicon tubing. A replacement fuse (240°C) can be purchased from many sources. The fuse should be re-attached to the wires with new all-metal crimp fasteners.
If the iron is getting too hot and blowing thermal fuses, you may be able to avoid this failure by keeping the thermostat set lower. (Turned a bit counter-clockwise.) If the waffles are no longer dark enough at the ready beep, you may have to use manual override by watching the steam and smelling the waffle.
May 19, 2010 | Waring WMK300 Professional Belgian Waffle...
Waffle plates stop heating
Apr 09, 2010 | Waring WMK300 Professional Belgian Waffle...
My waffle iron no longer heats up.just a red light
Had the same problem with the WMK300 that others are reporting. Plug it in, hear the click, red light goes on but unit does not heat up. Found the thermal fuse in the white insulation on the bottom unit. Found replacement at Radio Shack (http://www.radioshack.com/product/index.jsp?productId=2102788). Works great!
Nov 10, 2009 | Waring WMK300 Professional Belgian Waffle...
Waffle maker won't heat
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. A replacement can be found on Amazon.com at the following URL:
http://www.amazon.com/Thermodisc-Degrees-Celsius-Thermal-Fuse/dp/B000T9VEV6/ref=wl_it_dp_o?ie=UTF8&coliid=I2M3QCVRS1C1IV&colid=2LRN9SBBQ2MW7
Aug 24, 2009 | Waring WMK300 Professional Belgian Waffle...
Waffles stick to both sides of iron
Lightly oil iron prior to heating it up. Use 2 Tablespons of oil in recipe.
Apr 06, 2009 | Kitchen Appliances - Others
Waffle iron top not heating
Jerry G.
May 09, 2008 | VillaWare 2005 Uno Petite Waffle Maker
Waffle iron light is on but doesn't heat up
The same thing just happened to my waffle iron. It worked great for a few months and then no heat.
I took it apart and found the problem. Waring used a thermal fuse instead of a thermostat. The fuse is located between the waffle iron and the stainless cover. The issue I saw is that cooking oil (spray) gets in between the cover and griddle and soaks into the insulation covering the thermal fuse. The oil heats up inside there and shorts the fuse.
Replacing the fuse is easy and it is available at Radio Shack for $1.70 (part number 270-1321). It's a 442 degreeF.
The hard part about this job is diassembly and reassembly. I had to take the entire iron apart just to get to the fuse. It took about an hour to take apart and an hour to reassemble. Changing the fuse took 5 minutes.
Good Luck,
Jim
Nov 18, 2007 | Waring WMK300 Professional Belgian Waffle...
WWM200PC Waffle Maker will turn on but does not heat up
I fixed one of these for a friend - the problem was an open thermal fuse. This fuse is located in the fixed grill; it is clamped to the grill and is covered by a white plastic sleeve.
The replacement part should be a 240°C/464°F 10 - 15 Amp thermal fuse. NTE sells a part NTE8242 which works available from Mouser.com for $1.41 plus shipping.
May 25, 2007 | Waring WWM200PC Waffle Maker
VillaWare 2010 Waffle Maker Logo
51 people viewed this question
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
