Question about ViewSonic VX910 19" LCD Monitor
OSD Locked is on and blinking. Will not go off. If I unplug the monitor, press and hold 1, then replug, the OSD locked goes off, but then it comes back on again in a few minutes. If I hold 1 and it unlocks, the contrast or brightness box comes on but stays on and cannot be adjusted. Again, the unplug, 1, replug works, but only temporarily. A bit frustrating.
  • tedstepp Nov 14, 2010
    Thank you for your response. Your suggestion seems to be about how to use the normal procedure for turning the OSD on and off. However, on my monitor, the OSD Locked message stays on and blinks rapidly. If I hold button 1, it unlocks the OSD, but the unlocked message still stays on, and often the dialog boxes for brightness or contrast also stay on. When they are on, I cannot adjust the brightness or contrast. I have followed the suggestion online to unplug the monitor, then hold button 1 and replugging it in, and sometimes this turns off the messages, but soon they come back on again.
    I live in the Marshall Islands in the West Pacific, and shipping the monitor for repair is very costly plus takes time. Is there something I might do, or I might ask a computer person here to do?
    Waiting for a reply. Many thanks,
    Ted Stepp
    Thanks. I'll try your suggestions and get back in touch if I think you may be of further help. The small island I live on is near the equator and, even with AC, it's a very humid climate. It can wreak havoc with technology, and this may be my problem.
    Thanks again,
    Ted
  • 10,515 Answers
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
Let me know,if problem still persists.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
  • taran_2005
    taran_2005 Nov 14, 2010
    Thanks for your response!!
    OK!!
    If it's come back after few minutes, this is an internal fault. Either consider the possibility of front button faults ( you may want to try using a compressed air and spray inside through the narrow gaps between button and front panel ) or it could be a problem with electronic circuitry ( IC 7805 on most models ).
    I would rather prefer a TV repairman to have a look at it and fix it rather than computer guy trying to play with it.
    Let me know,if needed further assistance.
    Hope i helped you.
  • taran_2005
    You are welcome. Try that trick and hopefully that would work.
    Hope i helped you.
I am getting many times osd lock problem i am getting irritating so please give solution for unlock the osk lock on monitor.... or sometimes repeatedly blinking the main menu on the...
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Nov 26, 2010 | ViewSonic E70f 17" CRT Monitor
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
Help me my system is OSD Lock give me the solution.
Option 1: OSD lock - all 4 buttons are locked except the "POWER"
button. Press and hold the "MENU" and ">" buttons for 3
seconds to lock the buttons. Repeat this step to unlock.
Option 2: OSD & Power button lock - all 5 buttons including the
"POWER" button are locked. Press and hold the "MENU"
and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
Mar 06, 2010 | ViewSonic E70f 17" CRT Monitor
The button on the front has functions but when I press either the left hand side or the right hand side it just comes up with a message ''OSD Locked'' What does this mean
OSD Locked means that your On Screen Display is locked. That basically means you can't access/change the menu settings. The way to unlock the OSD varies from manufacturer to manufacturer and even monitor to monitor. Here are a couple different ways to unlock it:
1) The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
OR
2) Go to Menu and select OSD settings and change the setting for the OSD Lock. For example if it is a "+" then make it a "-" or a "On", then make it an "Off", or an "Enable" then make it a "Disable".
If neither of these work, I would contact customer support for your monitor from the manufacturer. They should be able to tell you how to turn off the OSD Lock.
Hope that helps. Good luck!
Feb 15, 2010 | Computers & Internet
Osd lock?
Depending on your monitor:
Solution 1
1. Disconnect power cord.
2. Press and Hold button 1.
3. Plug power cord back in.
4. If necessary, press power button while still holding button 1.
Solution 2
OSD and Power Button Lock Modes
OSD Lock This mode locks all current control settings and prevents access to
the control menus until this mode is unlocked.
? OSD Lock: Press and hold [1] and the up arrow  for 10 seconds. If any
buttons are pressed the message OSD Locked will display for 5 seconds.
? OSD Unlock: Press and hold [1] and the up arrow  again for 10 seconds.
See page 7 of this User Guide for further instructions:
http://www.viewsonic.com.au/support/manuals/files/LCD/Series%20X/VX715-2%20User%20Guide%20English.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
OSD lock should now be cleared.
Feb 04, 2010 | ViewSonic E70f (White) 17 in.CRT...
OSD locked how do I unlock
OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Sep 11, 2009 | AOC 917Sw 19" LCD Monitor
I am using view sonic monitor & i am facing a problem with it .At the centre of the screen there is a message in blue colour filled box that"osd lock"its irritating
OSD and Power Lock Settings
• OSD Lock: Press and hold [1] and the up arrow 􀁓 for 10 seconds. If any buttons are
• OSD Unlock: Press and hold [1] and the up arrow 􀁓 again for 10 seconds.
• Power Button Lock: Press and hold [1] and the down arrow 􀁔 for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display’s power will automatically
turn ON when power is restored.
• Power Button Unlock: Press and hold [1] and the down arrow 􀁔 again for 10 seconds.
Well this Should resolve ur issue
May 13, 2009 | ViewSonic E70fb 17" CRT Monitor
Osd lock
Dear srinivasvodn,
Press the menu button of your monitor for a wile OSD lock will unlock.
Aug 05, 2008 | ViewSonic 17" CRT Monitor
Problem in TFT
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jun 09, 2008 | LG L1915S 19" LCD Monitor
Compaq FP 7317 LCD Monitor
Check the buttons on your monitor for possible shorts. Sometimes pressing a sequence of buttons while turning the monitor on will lock the OSD.
Aug 02, 2007 | Compaq FP 7317 17" LCD Monitor
ViewSonic VX910 19" LCD Monitor Logo
197 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
