The color has changed to blue and red - Televison & Video
  • 454 Answers
You don't mention the make or model of TV. But if this is the older projection type TV, the green tube is out.
Posted on Nov 13, 2010
Toshiba 150r6f color blue is missing
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
The transistor that your friend told you, can be located at the CRT base card [Video Output] itself.
Mar 01, 2014 | Televison & Video
Samsung HLR5067 has no green color in picture
I know this may seem dumb but if you are using component video (the red green blue with the white and red audio cables) it could very well be that the green cable (carries the green signal) is the problem. try changing the configuration (ex: use blue to carry the green signal and vice versa) if the green starts to work and the blue stops then its just your cable.
Oct 18, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
Color bleeds
test first a) Video detector, then 2) AGC, adjust control, circuit 3) color Sync 4) color occ 5) color killer 6) color i-f 7)DEM red-gree-blue+videoamp red-gree-blue finally YOKE.see the b.diagram attached.
God bless you
Oct 17, 2012 | Televison & Video
HI, when printing in colour the blue appears as partially green
Usually this happens in inkjet, when you have a mix of the colors int he cartridge.
so, inkject usually have 3 colors, Blue, Yellow, Red.
If yellow color finds it's way towards blue, then instead of blue, you will see green.
Solution: change cartridge.
Aug 01, 2011 | Office Equipment & Supplies
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Wii only shows blue, yellow and black on my HD TV
Are you trying to plug in the yellow, red ,and white cables into blue, green, and red slots? If you are you cannot because those are for HD inputs only
May 06, 2009 | Nintendo Wii Console
Change the colour
CLICK HERE for a PDF copy of your owner's manual.
Page 17 States to change the display color -
Setting the Multicolor Illumination
ILLUMI BLUE (Initial setting) / ILLUMI GREEN/ILLUMI AMBER /
ILLUMI RED
You can change the lighting color of the following four buttons:
SOURCE/POWER, BAND, (left << arrows) and (right >> arrows).
BLUE > GREEN > AMBER > RED > BLUE
• According to the lighting color of the above four buttons, the color
of the other buttons also changes. When the color of the four
buttons is AMBER/RED, the color of the others is AMBER. When
the color of the four buttons is BLUE/GREEN, the others are also
GREEN.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | Alpine CDA-9847 CD Player
In visual basic how will we change the backcolor of the form randomly when we click the command button?
Paste this code on you button. This generates a random color.
Red = Int(Rnd * 255)
Green = Int(Rnd * 255)
Blue = Int(Rnd * 255)
Form1.BackColor = RGB(Red, Green, Blue)
Oct 06, 2008 | Computers & Internet
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
