Question about VeriFone Omni 3700
Light Printing Problem
The 3750 prints very light. How do you correct this. Thanks
Sometimes it is the wrong power supply. I have seen it before. You need to verify that it is the power supply meant for a 3750. If you use a power supply from a 3200, this problem can occur.
Posted on Oct 22, 2008
Call for a replacement unit. The printer prints by heating up the paper in a tiny dot. If it is not heating up enough, the printing is very light.
Posted on Jul 01, 2008
  • 6 Answers
Before returning the terminal simply check to ensure you have the paper inserted properly. Thermal paper will only print on one side. if inserted backwards and your printer runs hot then it is possible for the light print to "bleed" through the back lightly. If that is not the problem, then call in for warranty.
Posted on Aug 28, 2008
When this begins to occur it can be the roller mechanism inside the clamshell. If one side has a bushing that is going or is not getting firm pressure the paper, it will create issues for the printing mechanism. This is normally where I start.
Posted on Nov 08, 2008
I have a Mac5000. It's currently printing very light. Do I need to change a cartridge? What is best resolution? Is there something I need to adjust on machine?
Sounds like low ink. Try changing the ink cartridge befor yoy get into more stuff. If you check the manual might help.
Dec 18, 2014 | GE MAC 5000 EKG
Faint printing
Have you by any chance set the print properties to DRAFT? that will print a light copy to save ink and looks like what you describe. goto printer properties and select the correct mode or default.
Mar 24, 2014 | Brother MFC-7440N Multifunction Network...
Printing blank labels
Hi Sam,
Try running this steps on the printer:-
  • Turn on the printer.
  • Open the printer,remove the labels roll and re-load it again making sure its correctly done.
  • Close it and then turn it off and on.
  • Try printing.If still cant print,
  • Turn it off,press and hold the green feed button and then turn it on.
  • Release button after first flash of led light.
  • The printer runs a print test.
  • Now try printing.
Hope this helps.Thanks!
Nov 03, 2011 | Zebra LP 2844 Thermal Printer
Omni 3750 is only partially printing the recipts.
You either have bad paper or you printer head is going out. Firs, replace the paper. Thermal paper goes bad over time.
Jul 19, 2010 | VeriFone Omni 3700
Replaced paper in Omni 3750, now it feeds but doesn't print
Make sure you are using thermal paper and it is feeding from the bottom of the roll. If not press down on the lid when the paper is printing sometmes the tension springs were defective.
Feb 19, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
Printing problem
Turn off printer
Hold down green button
Power on printer. (cold reset)
In printer properties choose print directly to printer, then choose print test page.
Weird problem
Feb 06, 2009 | HP LaserJet 1320 Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
The red attention indicator light and the toner indicator light are both flashing together
ON your driver check that the paper size is correct and this most commonly occurs when the incorrect paper size is selected. For example if you are printing to A4 and you have letter size installed in the machine then the system will cause an error or jam when there is nothing there.
Also within word or which ever program you are using on the document goto file and then down to page setup once in there check the paper size make sure it's correct for the paper in your machine also check the paper source. Once you have done this check the paper tray guides are correctly against the paper turn on and try printing and hopefully this will work.
Thanks J
Oct 27, 2006 | Kyocera Mita FS 1000 Plus Laser Printer
Retail Supplies Logo
630 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
