Question about Motorola Mobility Moto Q
Motorola Q ( phone off)
Hi! on the top left side of my phone screen, it shows" phone off." I have no idea what it means? my phone is on but i can't receive any messages or calls....
Thank you very much!
    Problem Solver:
  • 10 Answers
Your phone may be in flight mode. Hold the home key until quick menu comes up and either select "Flight Mode off"
Select Wireless Manager, then highlight "Phone" and hit the center button.
Posted on Sep 03, 2008
  • 3 Answers
You can turn your phone off and your screen will allow you to do everything but ur phone is still off im not sure the way to go about fixing it call your carrier and tell them you need help finding out how to change that.
Posted on Sep 30, 2008
Turn off your bluetooth. that was my problem when it happened to me. Turning off the bluetooth, turned the phone on.
Posted on Sep 15, 2008
  • 87 Answers
Its a common problem.. try a hard reset
please rate this solution
Posted on Jun 19, 2008
Where is the voice key located?
Hi, you can locate the voce key from the top side of the side has a up and down button which is volume control, while the other one left at the other side is for voice key..
Hope it helped..
May 17, 2011 | Motorola Mobility RAZR V3
Hi, my name is issha ,since morning my motorola display screen is coming in white,not exactly white means it is showing blank faded white colour on whiole screen ,i am unable to call anybidy nor able to...
  • tell me the model of your cell phone .
  • if it flip type means definetly the problem comes from the joint part of upper part and lower part..
  • give to service center..
  • other model means the software must be corrupted re-install it..
  • If it's useful for you means plz rate me the 4 Thumbs ....
Jan 31, 2011 | Motorola Cell Phones
Motorola showing "no service",using idea num
you antenna could be faulty so it would be better to take the phone to a mobil service center to have it fix.
Dec 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Blank or White screen on new Motorola Krzr k1 cell phone
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out, or to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
Jul 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Speaker only
happened to me, i had to reset my phone, then go into the setup menu.
type ##332284, the 4 should not show up, press clr then top left. it should now say FTS on the top of the screen.
press top right, keep pressing top right till it says ServOpt: at the top , and a whole list of other things.
go down to AudioOpt: ; make sure this says AUTO. use top right to change if not.
when finished, press clr,clr,clr then top left.
Apr 28, 2008 | Motorola Mobility RAZR V3
Incoming calls
check to see if your calls are being forwarded. try *72 to deactivate if they are.
Feb 02, 2008 | Motorola Mobility RAZR V3
Screen problems with v3c
have the LCD and flexcables replaced...take the phone to a repair shop and have them fix it for you.
Jan 15, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Tries To Come on, But Screen Will NOT Light Up!
hi there.
the problem your having is caused by a ribbon that connects the screen and the mainboard in the phone.
the ribbon seems to have either come loose or detached.other than that being a problem it will almost certainly be a screen issue where the lcd has burnt out.
but in my professional opinion it will almost certainly be a ribbon issue
Dec 09, 2007 | Motorola Mobility RAZR V3
open the phone and press the top button on the left hand side. This will toggle the speaker phone between on & off.
Aug 30, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
258 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
