Question about Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive
My Maxtor Personal Storage 3100 back up hard drive is not working. I can hear the internal parts moving, but I cannot retrieve any of the backed up information. Any ideas on how I can fix this or where I can go to have someone professionally retrieve the information? Thanks, Col
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 13, 2010
Maxtor personal storage 3100 ext. HD (200 GB). When plug into electrical outlet, the on light does not come on, and when connected to my PC, it doesn't recognize it. I think the power cord is defective....
You can find a power cord for your Maxtor Personal Storage 3100 100 GB Hard Drive here:
http://lcdpayless.com/productpage.php?productId=2503
or
http://www.ecrater.com/p/6553550/ac-dc-power-adapter-maxtor-3100
Oct 31, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
UPGRADE DRIVER FOR MAXTOR 3100 EXT HARD DRIVE
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
My Maxtor personal storage 3100 clicking and not recognised
If you can hear mechanical sounds from the case the problem is in the hard disk and moving it to your laptop isn't the solution. In that case check for a data recovery company at your area as sooner as posible. If the sound is no mechanical I'll tell you the way to move the HD. Describe me the kind of sound.
Stelios
Feb 20, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Hi, I have a maxtor personal storage 3100 on which I have data that has been stored from my Dell Dimension computer that has XP. I want to transfer the information to my new DELL Studio computer with...
this message comes mostly due to the nonavailability of the drivers. so i would request you to first install the drivers of your maxtor personal storage 3100 to your DELL studio computer, then connect your maxtor storage to your DELL computer. this should fix your fix your issue.
Dec 08, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 internal hard drive not working think it might be the PCB Board not working.
It's possible that you're correct.
However, finding a Maxtor drive with an identical PCB is not going to be easy. Once you do, you can disconnect the "spinning" part of the disk-drive away from the PCB, and then swap PCB, and see if you can then QUICKLY(!) copy all 80GB to a "new" disk-drive.
Dec 05, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
My Maxtor Personal Storage 3100 suddenly not
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Nov 07, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
We moved our computer and re-connected our external drive (maxtor personal storage 3100) and the computer won't recognize it. how do I get It to?
try reinstalling the drivers for it if its a usb which most are try using a different usb port to re initialize the usb communication to it
Sep 28, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
Maxtor 3100 installation
It's Plug N Play. XP will see it (Found new hardware), and will install the drivers for you and assign it a drive letter and you will see it in MY Computer. However, there may be some other features and drive options you might like on the disk.
I have anexternal USB harddrive myself and am planning on gettng another very soon.
Mar 08, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
My computer will not recognize my maxtor personal storage suddenly when it has always worked before.
My Maxtor 3100 did work with my XP widow machine at one time. But suddently my computer doesn't recognize the USB connection. How do I fix this?
Proopt
Nov 09, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Does maxtor 3100 storage automatically add file to itself?
Yes, it is wise to do a house cleaning on your Maxtor. Whether you delete everything or not is up to you. However, do not do this by formatting the hard drive.
If you find you need a file later you deleted from the drive, a free program called 'FileScavenger' can recover it for you. If you format the hard drive the ability to recover a file becomes highly unlikely.
We techs have expensive software to recover files should you need to get it retrieved, but the interface is designed for techs and not the average user.
Regards,
Worldvet
Jun 08, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive Logo
115 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
