Question about Microwave Ovens
Savoureux pro line scale instructions - Microwave Ovens
I have lost the instruction manual for my eks manual kitchen weighing scales. Where can I get a copy from?
you can find the manual of your instrument in it's website.... otherwise give me the model number of your instrument i'll provide it's manual....
Aug 12, 2011 | Microwave Ovens
Its nan oxo pull out display food scale and the screen reads F when turning it on
My OXO scale has a removable weighing platform. I removed it and wiped off the top of the scale base. When I put the platform back in place and turned the scale on, the display showed the normal numbers and icons. The F was gone.
Apr 07, 2011 | Microwave Ovens
I can;t find manual and I want to clean my keurig coffee maker
You may be able to find the User Guide for your Keurig machine here:
http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help
Your brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar. Full de-scaling insturctions can be found here:
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Mar 26, 2011 | Microwave Ovens
I've lost the instruction manual on the nutri scales. Where can i get a new copy
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 17, 2011 | Microwave Ovens
I need the food code manual for my chefmate digital scale
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and Installation Instructions as required.
I hope this helps.
Jan 06, 2011 | Microwave Ovens
New CR2032 battery last about 1 week before the scales say that the battery is dead. Have tried lots of different battery brands and the same happens with all. We only use the scales a couple of times a...
Sounds like the scales have developed a leak across the battery and is draining the power. New scales maybe the best option but before that, have a look to see if there is any spilliage around the pcboard and/or battery terminals.
Jan 03, 2011 | Microwave Ovens
Shark Euro Pro Steam cleaner, I need the instructions for use
Hi
This is where you can get manuals ofr the whole range
Euro Pro manuals
hope that helps
Tom
EuroPro steam cleaner
Sep 16, 2010 | Microwave Ovens
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
Microwave Ovens Logo
189 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
