Question about Hardware & Accessories
I have a noisy TORK model1101 24hrtime switch there is a broken spring in there and it won't switch OFF is it repairable or do I scrap it and Hunt for a new one? If you cant give me and answer with out charging a fee you can bet I won't be buying any more of your products. Regards Len Bockman.
Fixya answers questions.
NSI is responsible for Tork.
http://tork.com/tork/elecmech.aspx
Electro-mechanical timers make audible click noise when timer turns on-off.
T1101 spring is the time-carryover for power outage.
Buy another Tork T1101 and swap out insides without changing box:
Take photo of wiring before making changeover.
http://www.weisd.com/store2/tork/torktimer1.php
Replace Tork with Intermatic T-101 120V timer
T101R for weathertight
Amazon for T101
Aplus sells T101R
For help wiring T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Posted on Nov 14, 2010
I took my microwave apart to fix the broke spring in the door & put everything back exactly the way it was &it wo nt do anything ??????
Bad luck. Are you sure you mounted everything everythinh exactly the way it was? No pieces missing or left over?
Best procedure is to that a photo of each step.
My adivec: Do it agaim carefulley. I no luck, look for a repair service
Maybe you can fine a video tutorial for your Microvwve in youtube?
Something like this
Broken microwave door
Samsung Microwave Door Latch Spring Repair when your door won latch closed
Over The Range Microwave Oven Door Repair Help
Repair Replace bad Door Switch Mechanisms on Whirlpool Microwave
and there are come more
Oct 28, 2015 | In Microwave Ovens
Trying to connect a Tork A530 MW timer to a spa tub pump
  1. The white wire (neutral) in your feed cable from the electric panel should be connected to the white (neutral) wire going to the pump.
  2. This switch is wired in 'series' in the hot (black wire) leg. That means one black timer wire connects to the black wire in the feed cable from your electric panel and the other black timer wire connects to the black wire that goes out to the pump.
  3. I the diagram the switch is your timer and the light bulb is the pump. The switch is in series with the pump.
Nov 13, 2013 | Tork Spring Wound Interval Timer
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
2006 Honda CRF 80 will not shift
Hi, Lacroseman20 and the usual suspects are:
1. Improper clutch adjustment or not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
won go into gear
XR70R Trans won go into gear 4Strokes com
CRF80F CRF100F service manual repair 2004 2013 CRF80 CRF100 Download... $15
https://www.partsfish.com/page/oem-parts-for-honda
HONDA CRF80F Owner Manual
Oct 01, 2010 | 2006 Honda CRF 80 F
Why my electrolux washingmachine is noisy specially when its spin time i already service it in yuir service center and it seems the problem is still unsolve can i ask another service center no. here in...
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 23, 2010 | Electrolux EW1000i Front Load Washer
LG GC299BA Fridge working but noisy, freezer broken.
It sound rather like one I used to have (but worse) which was never 100% satisfactory. When it eventually failed we called in a repair man who said it had been faulty since it left the factory.
I advise you to scrap it and but a new one. If you have any similar problems with new equipment, go back to the supplier within the warranty (if you have an extended warranty, then call them out now!).
Jan 23, 2010 | LG Refrigerators
TOP LOAD WASHER VERY NOISY. IT WAS NEW IN CONDO.
Mar 11, 2009 | Washing Machines
Hardware & Accessories Logo
115 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
