Question about D-Link DI-524 4 Port Wireless-G Router - RETAIL (DSDLDI524)
My D-Link Router isn't working. Everything is connected the right way. And when I go to Network Preferences, it says there is a problem with the Internet and Server. What can I do?
  • D-Link Master
  • 7,733 Answers
If the problem persist the router is not the problem, is your internet provider connection.
v
Posted on Nov 13, 2010
Hard wire computer works roku works [ wireless] But my laptop [wireless] isn't
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 08, 2012 | Linksys Wireless-G WRT54G Router
My wireless signal is indicated, it DOES NOT light up, no icon recognition at the bottom right for a signal, BUT the wireless router works for the desktops , 2 with NO problem
Try resetting it to factory default setttings. Use a paperclip to hold the reset button down in the back for 30 seconds. It will come up as "NETGEAR" with no security when it resets. Try to connect to it and see if everything works that way first, then re-set everything up as far as security passwords for the network and all. If it worked as NETGEAR with no security but not after you set up security, something isn't compatible.
Aug 21, 2011 | NetGear WNR2000 Wireless Router
I connected my new dlink 600 router to my cable modem. Not only does the wireless network not work but the ethernet connection does not work. On top of that I can no longer access the web directly...
When you connect a router to a modem, you should power everything off and restart in this order:
1. Power up the modem, allowing a minute or so for it to run thru its initial diagnostics. 2. Power up the router. 3. Turn on the computer.
It's best if for the first time you do this that you have a wired connection to your router. With the wired connection, you'll be able to setup the secured wireless passcode and the like.
Most likely, what happened was that your router wasn't interfacing properly with your modem and was spitting out 169.x.x.x IP addresses. This169 address signals that the Network Card on the computer isn't finding the DHCP server of the router which is what assigns IP addresses. By booting everything up in the order above, your problem should be solved.
Jun 20, 2011 | D-Link DIR-600 Router
D-Link wireless router has been greta, until yesterday- the Roku boxes say my router strength is excellant, but all of a sudden, the box can no loger connect to the Internet even when I select my router-...
The router most likely is not synced properly with the modem. Your computer might still have a strong connection to the router, but isn't getting an IP address. Power everything down, including the modem and restart in this order:
1. Modem - allow a minute for it to run thru its diagnostics 2. Router 3. Computer
Once you've done this, if you're ISP isn't having outages, you should have the internet working again on your computer. If this doesn't work, call your provider.
Jun 19, 2011 | D-Link DIR-615 Wireless Router
IMac, canon mx860, netgear router, error code 306. Things were fine for a couple of years but last week the router had to be replaced. Network signal says connected at 100% but error 306 pops up when I try...
  1. In iTunes, choose iTunes > Preferences (Mac) or Edit > Preferences (PC).
  2. Click the Advanced tab.
  3. Click the "Reset cache" button.
  4. Click OK and see if the issue is resolved.
Adjust Parental Controls in iTunes:
  1. Open iTunes.
  2. Access iTunes preferences:
    1. On a Mac: From the iTunes menu, choose Preferences.
    2. On a Windows PC: From the Edit menu, choose Preferences.
  3. Click the Parental Controls tab.
  4. Remove restrictions on Parental Controls.
visit the CBR Tech Solutions
Nov 26, 2010 | NetGear Computers & Internet
We plugged in the modem yesterday and ran the router and set up our wireless network. Everything was working fine on both our computers with our wireless network and neither one of us were plugged into the...
Your Wireless Router may have its name not broadcasting or hidden, check in the settings if it's hidden then manually connect your P.C.'s Laptops ,you won't find it using 'search for network'. Just right click on wireless icon near clock, select 'Open network and sharing center' and right click it. Now select 'Set up a new connection or network', Select 'Manually connect to a wireless network' and fill in the gaps. should work fingers crossed.
Aug 24, 2010 | D-Link DI 514 Wireless Router (DI-514)
Connection problem
The configuration on your Dlink may have been corrupted when the power was lost. Try to reconfigure your DLink router internet connection and your wireless network setting on the router.
Dec 20, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Have a new imac with leopard and it has a built in airport, how do i get the dlink on my pc to recognise it
To join an AirPort network:
1.
Choose Apple > System Preferences, and then click Network.
2.
Click AirPort in the network connection services list and choose a wireless network from the Network Name pop-up menu. Enter the password for the network if necessary.
If the network you expected is not in the list, it may be a “closed” network and not be available in the list. Try clicking Other, and then enter the network name and password if necessary.
If AirPort isn’t in the list, click Add (+) at the bottom of the list, choose AirPort from the Interface pop-up menu, give the AirPort service a name, and then click Create.
May 08, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Mac won't recognise network
Based upon the way you worded the message, you were trying to get the Mac working wirelessly? The description of how you were trying to set up your network (SysPref\Net\BuiltInEthernet) is for WIRED connections, not wireless. If you are running OSX and you have a built-in wireless adapter, use System Preferences\Network\Airport choice to set up for wireless connections. If you are trying to use the wire either because you don't have a wireless card or it is not working, check to make sure that the cable is good...maybe hijack the cable that you know works for your PC and test it. Please let me know if I am on the right track to solve the problem.
Jun 12, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-524 4 Port Wireless-G Router - RETAIL (DSDLDI524) Logo
62 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
