How do I physically connect a wireless router using ethernet cable to wireless network?
Cannot connect to 192.168.1.1 to set up wireless in my router
If you fail after ping your IP address then it may be problem in your physical connection,so you should check connection like:
check cable modem status light. If it is solid green, it indicates that your cable modem has a good connection. If the light is off, check modem's physical connection.
Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring. If the light is off, check the Ethernet wire's connection between your modem and router.
May be it can be cause of Incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
***If you need any kind of technical assistance you can contact support cell at here
Feb 01, 2013 | Actiontec GT704WG Wireless Router...
I am aolder mother, I have a reader, and my son gave me a linksys wireless and I don't know how to hook it up and I need a password that I don't know thanks Lynette Bigler
Physically connecting the wireless router is the easy part, configuring it can be difficult unless you know what you're looking for.
The physical part:
Depending on the type of internet connection you've purchased from your ISP, you will have a coaxial cable or a telephone cord going into a modem provided by your ISP. That modem should have an ethernet or network port on it. You need to plug an ethernet cable into that port and plug the other end into the WAN or Internet port on you wireless router. You should now have internet connection from the wireless router. Try scanning for available networks on your wireless device and see what comes up. If you see one that says Linksys then this may be yours(could be your neighbors depending on how close they are to you). You could also plug a network cable into the router then plug the other end into your computer. If you can get to Google.com or Fixya.com then your internet connection is working.
The default IP address of the wireless router should be 192.168.1.1. This address is used to configure the router. The default password to configure the router is probably "admin" (without the quotes).
Here is a link to a web page that has some pretty good directions on securing your wireless signal.
Here is some more information:
http://compnetworking.about.com/od/wirelesssecurity/tp/wifisecurity.htm
Mar 31, 2011 | Linksys Wireless-G Broadband Router
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
I am trying to connect my new router to my laptop,but the instructions say i should connect my pc to the internet by connecting my ethernet cable to the router.my problem is i have only one connection and...
Modem <-- Ethernet cable --> WAN port on router
LAN port #1 on router <--- Ethernet cable --> network-port on desktop computer
LAN port #2 on router <-- Ethernet cable --> network-port on laptop computer
If the router has built-in "wireless" capability, then use the desktop computer's connection to the router to "configure" the wireless adapter, i.e., pick an SSID, and establish a password, and then your laptop computer can use the SSID/password to connect "wirelessly" to the router.
Mar 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
Whre is my WEP key
It's a value electronically stored "inside" your wireless router.
It is not a "physical" key (unlike the key to your motorcycle).
Connect your computer to the router, with an Ethernet cable, and access the router's built-in web-server, and run the "Wireless Network Setup Wizard", to define your wireless network, and to set a WEP-key.
Jan 09, 2010 | NetGear WGR614 Wireless Router
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wireless Repeater/Bridge (Belkin)
http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=1564&scid=0reset to factory defaults and reset up your laptop All info at factorywebsite here at this web address.RICHARDM69
Nov 30, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin router with a laptop
1. First you need to configure your router with your laptop wired or physically connected to it.
2. Connect your modem to router's WAN/Internet port. Then your laptop will be connected to the one of the router's Ethernet port using an RJ45 or Ethernet cable.
3. You may run the setup cd that came with the router. Configure it with the Internet connection type that Bell Sympatico requires.
4. The setup cd will also require you to set up wireless in the router. Once it is done, disconnect your computer from the router.
5. Enable wifi in your laptop and select the wireless network that you set up and connect to it.
Nov 08, 2008 | Computers & Internet
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
