Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
I have a Stihl MS210c chainsaw. I changed the Ignition Module twice and tried to set the gap at .010 and .012 and I cannot get any spark. I have disconnected the three wires and still no success. Ready to dropkick it. Please help.
  • 173 Answers
Make sure all the wires are hooked up to module.Then unplug ignition switch and test for spark.If you get spark then switch is bad.
Posted on Nov 17, 2010
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
I rebuilt my stihl ht75 pole saw with a new piston, rings, and housing, all OEM. It won't start now. I confirmed the orientation of the piston, it gets, gas (fresh) and has spark.
theres your problem. air gap on the module is 10 thou not 30 thou. set proper and if that is your only problem then unit will start
Sep 12, 2014 | Stihl Garden
Spark plug gap
check the switch and the switch cables. timing gap on the ignition module 0.025 feeler gauge
Apr 02, 2014 | Stihl Garden
Can't get a spark on Stihl 020 chainsaw. Tried another coil and switch module but still no spark
It is possible your flywheel has lost it's magnet strength, if you noticed it turn a blue. Can take off flywheel and replace with a good one. Or you can play with the gap on the magneto/coil, and insert a piece of paper between the coil and the flywheel magnets, to set for air gap.
Sep 09, 2013 | Stihl Handle Chainsaw 020 Avp
Stihl 018c will not start
Are you getting a spark..? - NO? check wiring loom from ignition module, check timing gap between flywheel and ignition module, check on/off switch.
Does it have compression.? - NO? then check piston/rings and cylinder
Is fuel getting to the cylinder.? - NO? Carb problem of fuel line issue
More detailed information needed for accurate diagnosis.
Feb 17, 2013 | Stihl Garden
How do I gap ignition module on a TS350 Stihl concrete saw?
I thought the unit was under the flywheel, in this case there is no gap to set it just screws to the crankcase and you re fit the flywheel.
Sep 18, 2012 | Stihl Chainsaw Cutoff Saw Flywheel 08 S...
Chainsaw has no spark replaced module still no spark
If you have changed the plug and have it firmly earthed against the cylinder and there is no spark pull the earth cut out wire off the ignition unit to rule out the switch and wire, now try again, if still no spark replace the ignition unit.
Jun 12, 2012 | Stihl Garden
Weak spark hard start stihl 021
Check the pole gap on the ignition module to the flywheel magnets. Use a thin business card for a gauge. If it has the correct gap and you have tried a new spark plug, then the module itself is likely failing. Hope this helps!
Apr 14, 2010 | RTO Spur Sprocket For Stihl 017, 021...
No spark in stihl 025 chainsaw. I replaced the
check the ground wire on the on and off switch, it could be a bad ground
Mar 15, 2010 | Standard Oregon Chainsaw Chain For Stihl...
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
457 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
