Question about HP Pavilion dv6000z Notebook
My hp dv6ooo laptop wont power up,when i press the power button it turn on for about 1 sec then shut off
  • 3 Answers
I had a similar problem with an HP laptop. I had to pull out the battery, make sure the laptop was plugged into a power source and then power it on. It should boot up with the battery out. Once it is on and stays on, you can replace the battery and it should charge. If it has Vista, you probably need to add extra RAM to it. When I researched the problem, I found out that the manufacturers were selling notebooks with inadequate RAM for the Vista program. We also had to get a new power adapter for it. We then used the original restore disk to bring it back to its original settings and now it operates so much faster and doesn't stop when downloading from the Internet or from email. Like a brand new computer. (If you use the restore disk make sure to back up all your personal files or anything else you need to put back on that wasn't on the computer originally. The restore disk, which should have been in your original box, will erase everything you added to the hard drive. Easiest way to backup your files is to put them on a memory stick.) I'd be interested to hear if this helps with your problem. Good luck.
Posted on Nov 13, 2010
  • kmkrreeves1 Nov 29, 2010
    and more ram and a restore always makes any computer faster
  • 2,567 Answers
Did you try to power the laptop up with the battery removed?
Hp dv7 wont turn on
It sounds like your power adapter is not putting out proper voltage...
Try removing the laptop battery and see if the laptop will power on when plugged in with no battery connected. If it will not power on this way, then test with another power adapter. If still no good, then it should go in for service. Please let me know if this helps or not.
Joe
Apr 24, 2012 | HP Pavilion dv7-1137us Notebook
My compaq presario v3500 wont turn on again. i was using it, watching movie then it suddenly shutdown. my battery is fully charge and the charger was connected. so i try to turn it on and it wont start....
Remove the Battery and press power on for 1-2 minutes with out AC power .
Please turn on the laptop with only AC POWER (without battery ). Check it. it may turn on your laptop.
If display ok, then insert battery and use it...
Jun 18, 2011 | HP Compaq Presario 2200 Notebook
Canon error b200 in ip2700
1) Press and Hold the On/Off button for 1 sec. until the printer shuts off.
2) Unplug the USB cable and then the power cord.
3) Press and Hold the power button for 1 sec. this should turn the printer back on.
4) Wait 10 minutes, then plug the power cord back in and then the USB cable.
5) Press the power button to turn it on again. that should get you working.
Jun 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My hp 213 wont power on. what is the problem? could you please assist me
try to do this:
- remove the battery and charger (everything
connected to the pc) then press the power button
for 1 minute.. - plug back in the charger - after few secs try to turn it on
hope this helps :D
Mar 23, 2011 | HP 2133 Notebook PC
Hp lansing wont turn on.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Apr 04, 2010 | Sony VAIO R505JL Notebook
At times pc wont turn off with mouse windows shuts down but computer will turn off and on again immed
Try draining the power of the computer first. completely shut it down by pressing poweer button for like 5-7 sec. then unplug power supply from the outlet. then press and hold power button for another 15-20 sec. After that, plug back in the power cord, and turn computer on normally.
Apr 03, 2010 | Compaq Presario 5000 PC Desktop
I turned my compaq notebook on and it turned right off and wont power back up
Try to remove battery and power adapter.
Press power button for 3-4 sec.
Plug in the power adapter.
Power on. After that you can connect the battery as well.
Mar 09, 2010 | HP Compaq Presario 905US (470045-353) PC...
HP Pavilion dv6700 Entertainment wont boot
1. Power on (NO Disc.)
2. Press Pause
3. Enter 314159(with remote)
Display will show "FF"
4. Quickly press "0" (for all region)
5. Press pause
6. Power off and powere on after 20 secs.
Dec 09, 2009 | HP Pavilion DV6700T Notebook
My HP Pav laptop just died (shut down on me) and wont turn on
1.remove the battery and disconnect the power cord from the laptop. 2.hold down the power button for 1 minute 3.now connect it only to the power cord.keep the battery away 4. as soon as you press the power button to turn it on, keep on tapping F8 key. 5. If you see advanced option, you can choose safe mode with networking and it hit enter. 6. now remove the security like Norton or macafee and scan it with malwarebytes(www.malwarebytes.com) 7. Now, restart the computer 8. If data is not important you can restore the computer to the factory setting, but all of the data would be lost. 9.to restore the xp computer start press F10 at the startup 10. to restore the vista computer start press F11 at the startup.
Dec 08, 2009 | HP Pavilion dv9000z Notebook
The hp altec lansing laptop wont turn on, you press the power button and you get this flashing electric looking icon that comes on and it's pluged into the wall. what could be the problem?
my hp altec lansing laptop doesn't opwer on, the button lights up for 1 second and then shuts down,nothing happens to the screen, it stays blank
Aug 27, 2008 | Sony VAIO R505JL Notebook
HP Pavilion dv6000z Notebook Logo
571 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
