Where can I get a goodman dependable 92 manual?
  • 2,418 Answers
I got my Goodman split system manual here >> http://www.manualsonline.com/ You sign up with your e-mail address.
Posted on Nov 14, 2010
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
Dependable 92 ignitor
check continuity on hot surface igniter. no measurable ohms reading = bad igniter. also insure 120v getting to the igniter
Jan 26, 2014 | Goodman GMS90703BXA Heater
DEPENDABLE 92 WON'T START . ALL SWITCHES CHECK OUT. CAN'T DIAGNOSE CIRCUIT BOARD
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Oct 02, 2011 | Goodman GMS90703BXA Heater
I have an NTL remote for a goodman television how can I make the remote operate on the TV what is the code
There are different codes depending of tv brand. Check the owner's manual for the set up procedure or the internet with the remote model number.
Jan 27, 2011 | Goodmans Televison & Video
Yeah, im at a friends house who has a dependable 92. During the summer the power cord got cut by a weed wacker. An electrition came and repaired the power cord and the entire systems still wont work. I was...
Does the furnace still work or is everything out. I would check to see if the wires from furnace control board to contactor on a/c were put back together. They will be two very small wire from thermostat to a/c to pull conntactor in when a/c is called for.
Dec 13, 2010 | Goodman GMS90703BXA Heater
Goodman GMP075-3 not igniting. Everything cycles as it should but HSI does not glow. Thermostat is set to heat, temp approximately 10 to 15 degrees higher than room temp, blower motor starts, relay clicks...
The flash code is due to the furnace not proving flame 3 times in a row. If you have a multimeter you can ohm the ignitor out to see if it is good. Depending on the type (silicon Nitride or silicon Carbide) you can verify if it is good. A silicon Nitride ignitor looks like a small thin straight bar type will ohm @ 11 - 18 ohms, a carbide ignitor looks kinda like a tuning fork (sorta) will typically ohm @ 40 - 92 ohms. anything outside of those ranges will require a replacement.
Nov 02, 2010 | Goodman GMS90703BXA Heater
Air not coming out full force
Check the circuit breaker for the indoor unit. Also make sure the fan rotates freely by hand, then check the capacitor for the fan motor and replace it if bad. If the capacitor is good then check the fan motor windings to see if the fan is bad.
Jul 20, 2010 | Goodman Heating & Cooling
Common problems with 92 honda 5 speed
A/C Problem usuallyabout 200,000 miles (specifically high pressure hose leaks and compressor clutch usually within 30,000 miles of the hose going.)
At about 250,000 miles or so the main relay goes usually at about 290,000 Torque convertor in Automatic Transmission starts to slip.. Manual tranny can't say too much there depends on how you drive . replace clutches at every 50K or at 150K depends on driver.The cat and the mufflers usually go at abot 190,000 give or take (depends how much water you drove threw). Lastly fast idle cam valve about every 120,000. As you can see this is a great car to own.
Mar 09, 2010 | 1992 Honda Accord
Goodman Dependable 92, ignitor and fan comes on for 3 seconds, furnance does not turn on. Goes through 3-4 cycles, then shuts down furnance. If it is the flame sensor, where can one buy parts?
Do the burners come on? If so then yes it probably is the flame sensor if not then there is another issue not the flame sensor. The flame sensor could just be dirty take the flame sensor out and clean it with a piece of emery cloth or lite sand paper and put it back in and this should get the burners to stay on.
Feb 05, 2010 | Goodman GMS90703BXA Heater
Goodman Dependable 92 blowign cold air only - no heat
blowing cold air on this furnace usualy caused by high limit trip, or flame roll out. the first one, (high limit) is from insf. air flow. (blocked filter,bad zone damper?
The second,(flame roll out) caused by bad heat exchanger,blocked vent.ect.
Jan 09, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
