Question about Maytag Neptune MAH5500B Front Load Washer
How do you soak whites in this washing machine. I do not have a soak cycle
    President:
  • 1,654 Answers
Hi I tried to answer you but somehow I think my answere was lost so I will try again. I think you should be able to add the clothes and detergent that you want to the machine. Start it normally and when the wash cycle starts, simply stop the machine and let it set for as long as you want then start it up and let it finish the wash cycle. Have you checked the operators manual? How about taliking to someone from the store you bought this at, they might be able to help you with the specifics of your machine.
Posted on Nov 14, 2010
What is Soaking program?
is when your machine stops few times in the cycle, for example dirty laundry, or white cloths with bleach this cycle should be follow by a normal washing cycle
Dec 26, 2015 | Washing Machines
How do you short short wash cycle
i would not advise to temper the switch or you will invalidate your warranty. depend on how your dial controller set you timing. use the shortest time cycle on your machine and soak your clothing overnight, then use cold water on short wash cycle.my wife does it all the time and separate the white and dark material will help a lot.
Mar 02, 2015 | Washing Machines
Frigidare (GLTF2940ESO) front load washer
Hi , I would like to know how to soak my whites. When it is on a full cycle Thank you
Dec 11, 2012 | Frigidaire ATF6000ES Front Load Washer
I want to keep the water in my Roper top load washer overnight so it will soak the load of whites I have started but the machine drains.
You should be able to select a soak cycle without having to turn off the water supply, but it may time out eventually and drain the tub. This p[events oversoaking the clothes
Oct 13, 2012 | Roper RAS8445KQ Top Load Washer
How does the soak cycle work. Does it start at the end of the wash cycle, or does it drain the soap and soak in clear water
typically on the soak cycle it will fill with water..pause and soak then at the designated time it will advance into the regular agaitate/spin cycle
Aug 26, 2011 | Fisher and Paykel GWL11 Top Load Washer
Rinse cycle
If the machine has a soak cycle, you can use that. If it does not, you can have it fill on a cold rinse, and then stop it for a soak. Restart it on a hot wash with a cold rinse. Tumble dry low.
May 14, 2009 | Ariston Technologies AWD 129 NA Washer/...
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Wash/soak cycles will not work
Just cycled thru the switch several times and all of a sudden today it started working on the wash cycles
Jan 07, 2009 | GE WDSR2080D Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
