Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
I need a test fax to see if i can receive on my hp office jet pro 8500.
  • HP Master
  • 1,679 Answers
Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
When your fax is received by the HP Test Fax Service, It will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Posted on Nov 13, 2010
Can I received fax on my pc for my HP office Jet Pro 7580L
Hello.
The Fax can only be received and printed from the unit.
If you have a 56k modem in your PC with a phone line input you can set up a fax through windows. Simply go to control panel, printers and faxes and follow the instructions to install a fax driver.
Then you can receive the fax directly to your PC without having to go through the HP Printer at all.
Regards GM
Aug 01, 2011 | HP OfficeJet Pro L7580 Color All-in-One...
I keep getting error message 344
There is a good chance that your fax line is bad. Determining where it may be bad is a bit more difficult. There are a number of places that it could be bad, one of them should be replaceable by you. You can try a different phone line between the 8500 and the fax wall jack. You can try the 8500 at a different fax wall jack (if you have one). If you have DSL Internet service, make sure that you are using a DSL filter in between the fax wall jack and the line that connects your fax machine.
The final thing you can do is hook up a phone to your fax line, do you hear static? If so, you probably need professional service to assist you. Those are a few things you can do on your own to resolve a line issue. If that doesn't fix it, you might have to call out a phone company to check/test/re-run the phone line to your fax wall jack where you plug the 8500 in. It might even be a problem outside of your house/office/building.
Beyond line issues, there really isn't much it could be besides the fax machine itself. Try taking it to someone elses home/office and test it there. If it has the same issue, it is probably the machine itself.
There is one setting inside the 8500 you can turn OFF to attempt to bypass the issue, however this is just a bandaid. Look at your instructions to disable ECM or follow the link provided by HP for error 344 below:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549#Error344
Jun 16, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
We have the HP office jet pro 7780 I have a new phone number and need help programing a new number in the fax machine to receive fax
1 Click the Set-up button 2 Go to Fax Settings/Fax Set-Up/Basic Fax Set-up (Whatever you get to see first) 3 On Fax Header, press okay 4 And then just enter your name, hit ok 5 And then it will be asking you to enter your Fax NUMBER 6 HIT OKAY again.
I hope this helped.
Feb 08, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Lost my down load disc for my printer (HP office jet Pro 8500). I'm not able to use my scan.
uninstall drivers and reinstall drivers from hp.com's website:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3752456&lc=en&cc=us&dlc=en&lang=en&cc=us
Note, there are 3 or 4 different versions of the office jet pro 8500.
Not yours? Then input the proper one, according to your documentation or stickers or box.
Jul 16, 2010 | HP 8500 Premier All-In-One InkJet Printer
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I need fax confirmation sheets printed when I fax from my HP Office Jet 8500. How do I get them to print?
on the printer itself --> press the setup button--> use the arrow keys on the printer and move to print report option --> press ok when you select print report--> Find out fax confirmation option and press ok --> turn it on.
If you do not find the Fax confirmation option under print report then find it under Tools option.
Press setup on printer --> press arrow key on printer and finid tools --> under that try to find the fax confirmation option.
once you switch on the fax confirmation option on the printer. every time you send a fax you will receive a fax confirmation also.
May 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Where can i find hp office jet 8500 print heads
Try staples or home depot if they are still open otherwise you have to order it from HP or you could try the new egghead. HP's address is www.hp.com
Mar 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Can't get my hp office jet pro 8500 to receive or send faxes. Husband lost the instruction manual.
Follow this link to HP Customer Care: http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&lang=en&tool=&query=OfficeJet+Pro+8500#N447
Select your OJ Pro 8500 Model (A909n - basic, A909g - wireless or A909n - premium). On the next page, Select 'manuals'. From there you can access (read online or download & safe to your hard drive) all of the manuals.
Nov 02, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
195 people viewed this question
Seeker5211
Seeker5211
