Question about Precor 935 Premium Series Treadmill
I have a 2006 Precor 935. My son used it training some for the military and had about 285 lbs on it ( 80lbs of weights) running at 7mph. Since then the treamill stops at speeds above 5 mph. It has less than 600 miles of usage.
  • Greg Ayers Nov 15, 2010
    1. No problems if you're walking at a lower speed.
    2. Everytime you start running at the higher speed it stops. Sometimes it times a couple of minutes before it stops. There is an unusual noise coming from the motor. I pulled the cover off to verify and its the motor not the track/rollers. Doesn't sound like a normal bearing noise. Motor turns freely and has no rub feel but it still makes the noise.
  • 10,515 Answers
Kindly provide few more details :-
1. If you run it at a lower speed, have you ever noticed an issue with the machine?
2. Is it an intermittent or eveytime you increase the speed to above 5 mph, it would stop?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
How to remove fuel pump
The fuel pump is an electric pump paired with the fuel level float assembly and is inside the gas tank. You will have to drop the tank down and completely remove it from the truck. It has a white screw top cover ring that has to be unscrewed (counter clockwise) to remove the fuel pump assembles. Some of these units are constructed in a manner that will let you replace just the pump itself,
others are somewhat sealed units that require the replacement of the fuel pump along with the fuel level float assembly. FYI gasoline weights close to 8 lbs a gallon so if you have 10 gallons left in the tank it will weight around 80lbs.
Jul 21, 2014 | Dodge Dakota Cars & Trucks
Removing a user I'd password from a precor 935 2005
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Dec 21, 2013 | Precor 935 Premium Series Treadmill
What are weight training belts?
Weighttraining belts are belts that take pressure away from the lower back duringheavy lifting exercises (such as squat, deadlift, military press, etc.),therefore protect you from an injury.
Jul 25, 2012 | Exercise & Fitness
Precor treadmill error L5
Precor Error LS, Speed Sensor Signal Missing Probable Cause 1. Intermittent or open connection of the speed sensor (reed switch) wiring.
2. Reed switch is defective or has intermittent connection.
3. Drive motor brushes are bad.
4. Lower PCA is bad.
Corrective Action
  1. Inspect the speed sensor (reed switch) wiring for damage or poor connection to the lower PCA. Replace damaged wiring or reset connection as necessary.
  2. Using an ohm meter, test the reed switch while rotating the drive pulley. The reed switch will close when the magnet passes in front of it.
  3. Inspect the drive motor brushes and replace if necessary.
  4. Test unit with a known good lower PCA. Replace lower PCA if nec
Precor Error Code LS
Feb 25, 2012 | Precor 935 Premium Series Treadmill
I have a precor 935 that is showing error 5 stuck key that wont clear. any ideas
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Feb 01, 2012 | Precor 935 Premium Series Treadmill
What is the towing capacity of a toyota sienna?
2006 Sienna Standard towing specs:
2WD or 4WD: Max Tongue Weight: 200 lbs
Max trailer and cargo weight: 2,000 lbs;
(over 1,000 lbs requires trailer brakes)
Max trailer and cargo weight: 3,500 lbs WITH the factory tow package
Thanks for using FixYa!
Feb 16, 2010 | 2006 Toyota Sienna
Towing capacity for an Isuzu I370 pickup
As listed in the owners manual.
Weight of the Trailer
How heavy can a trailer safely be?
It depends on how you plan to use your rig. For
example, speed, altitude, road grades, outside
temperature and how much your vehicle is used to
pull a trailer are all important. It can also depend
on any special equipment that you have on
your vehicle, and the amount of tongue weight the
vehicle can carry. See “Weight of the Trailer
Tongue” later in this section for more information.
Maximum trailer weight is calculated assuming
only the driver is in the tow vehicle and it has all
the required trailering equipment. The weight
of additional optional equipment, passengers and
cargo in the tow vehicle must be subtracted
from the maximum trailer weight.
The following charts show how much your trailer
can weigh, based upon your vehicle model
and options.
2WD Extended Cab Axle Ratio Maximum Trailer Weight GCWR*
Automatic Transmission,
2.9 L Engine 3.73 3,100 lbs (1 406 kg) 7,000 lbs (3 175 kg)
Manual Transmission,
2.9L Engine 3.73 2,100 lbs (952 kg) 6,000 lbs (2 721 kg)
4WD Crew Cab Axle Ratio Maximum Trailer Weight GCWR*
3.7L Engine 3.73 4,000 lbs (1 814 kg) 9,000 lbs (4 082 kg)
*The Gross Combination Weight Rating (GCWR) is the total allowable weight of the completely loaded
vehicle and trailer including any passengers, cargo, equipment and conversions. The GCWR for your
vehicle should not be exceeded.
Aug 26, 2009 | 2006 Isuzu I 370
???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Apr 27, 2009 | Precor C956i Treadmills with HR /...
2006 reo passenger air bag light says its off. how do i turn it on?
The passenger air bag will only come on if there is weight in the seat. The manual says 40 lbs, but it is more than that. When my 60 son sits in the front, the air bag stays off. This is a safety mechanism. An air bag can kill a small child, so it automatically turns itself off if there is little or no weight in the seat. Also saves having to have the air bag repacked if you have a wreck with no one in the front passenger seat--a costly repair.
Aug 04, 2008 | 2005 Kia Rio
Precor 935 Premium Series Treadmill Logo
142 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
