Question about Siemens Gigaset 4000 Classic Cordless Expansion Handset
Speaker van siemens gigaset 4000 classic is 'dood' geen geluid wordt weergegeven, geen spraak en geen belsignalen. Wat kan ik daar aan doen?
CORDLESSGURU
  • 106 Answers
SOURCE: Siemens Gigaset 4000 No Sound
Hi Krister,
It sounds from your symptoms (no pun intended) that your handset receiver/speaker has gone bad, or if you use a headset, the circuit might have gotten ripped open from tension from the headset plug. You can try plugging in a standard 2.5 mm plug headset into it (real common headset). My guess is that you will be able to hear dialtone using a headset and use the phone, but the phone will continue not ring or make key beeps.
Its fixable, but with the Siemens models don't let anyone try to open it. To work properly it needs to snap together tight, and guaranteed they will gouge the plastic and break the more than 10 tabs that keep it held snug together, there are no screws. The skill to open them without damaging them is proper training and muscle memory, which is reserved for the people that do it daily, plus if the plastic needs replacing it will add to your costs. Nevertheless, if you want it fixed, just google "Siemens Cordless Repair" and click the first or second non sponsored link to make arrangements to get it fixed. Good Luck and let me know if I was right about the headset audio.
Posted on Jan 11, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: my siemens gigaset 4215 and 4000 don't work and need some kind of code whats the code?
Hello, Almost never is it the handset that is bad when those symptoms occur. It sounds as if your base has gotten hit by a power surge and won't boot (the handset now can't "talk to" the base and its always searching for it). Most people report this after a storm has passed through their area. You can try re-registering the handset to the base, but unfortunately it probably won't work, sorry. You can order the base only and register your handset to the replacement base when you get it. To order a replacement base using google, search for Siemens Cordless Repair and click the first non sponsored link. Good Luck
SOURCE: Problem Siemens Gigaset 4000 and 4200
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
  • 3230 Answers
SOURCE: need a manual for siemens gigaset as185 or as185
Well you can please follow the below link to get your manul -
http://gigaset.com/medias/sys_master/A31008-M2026-L101-1-7643_en_GBR.pdf
Good Luck!!
Posted on Apr 02, 2010
singlemac01
  • 59 Answers
SOURCE: How do you put the
when receiving a call u put it to the speaker
Posted on Mar 10, 2011
Mijn vraag is ik heb een Philips CDR 560 cd recorder alles werkt maar de VU meter geeft geen geluid signaal aan en er komt ook geen geluid uit de cd recorder als ik een cd wil afspelen terwijl de...
typically english is the prefered language to seek assistance. By submitting your query in non-english, you have reduced the potential for help by 800%
Oct 26, 2014 | Office Equipment & Supplies
Tip
Cavity wall insulation
Er zijn altijd creatieve Vlamingen die denken dat elke subsidie meegepakt moet worden. Zo gaan zij proberen om de optimale hoeveelheid subsidie te krijgen van de overheid. Wat doen deze mensen die gaan nieuwe kozijnen plaatsen. En als ze dat doen in combinatie met het na isoleren van de spouw (spouwmuurisolatie), dan krijgen ze 2x zoveel subsidie voor de nieuwe kozijnen als zouden zij dit niet doen. Maar zoals altijd is het niet aan elke slimmerik gegeven om deze subsidie binnen te halen. Ze hebben wel het papierwerk ingevuld en bij een bevriende aannemer een factuur gehaald voor leveren van de dienst. Echter wonen ze in een huis wat is gebouwd begin jaren '90. Nu is de overheid niet helemaal van gisteren en stuurt een controleur ter plaatse. Het is namelijk zo dat huis met een spouw werden gebouwd tussen 1920 en ongeveer 1980. Daarna werd er glaswol in de spouwmuren geplaatst voor een optimale isolatie. Wanneer men wordt gepakt voor een dergelijk vergrijp, dan wordt niet alleen de subsidie niet uitgekeerd, maar ook wordt er een strafrechtelijke procedure opgestart. Deze wordt niet alleen tegen de fraudeur ingesteld, maar ook richting de aannemer. En voor deze partij kan het nog wel eens veel grotere gevolgen hebben, omdat men geen opdrachten meer krijgt van de overheid. In het slechtste geval raakt de firma zijn aannemingsnummer kwijt wat wettelijk verplicht is.
Maar gelukkig zijn er ook brave Vlamingen die een keuze gaan maken om de spouw te laten opvullen. Hierbij moet men vooral niet uit het oog verliezen dat de technieken op elkaar lijken, maar datgene wat er in de muur wordt gespoten zeer verschillend kan zijn.
Spouwmuurisolatie, de verschillen
Er zijn een aantal stromingen gaan, maar steeds meer aannemers kiezen de wijze van isolatiemateriaal waar het grote publiek om vraagt. Je kan als aannemer wel kiezen voor andere isolatieproducten, maar dan mis je op de lange termijn de boot. Daarbij is het aantal na te isoleren huizen niet oneindig. Eens dat alle huizen in Vlaanderen zijn aangepakt moet je het terrein verleggen naar het buitenland. Hierbij moet je denken aan alle landen waar men te maken heeft met slagregens. De spouw tussen de buiten- en de binnenmuur moest er voor zorgen dat alleen de buitenste muur vochtig kon worden en er geen 'koude brug' werd gemaakt met de binnenste muur. Indien dien dit wel zo is, ontstaat optrekkend vocht. Dit geeft uiteindelijk schimmelvorming in huis.
Spouwmuurisolatie producten
De ingespoten producten zijn:
Glaswol
In de muur wordt inblaaswol ingebracht wat een soort glaswol is. Deze is het meest populair in Vlaanderen.
EPS Parels
Er kan ook worden gekozen voor EPS parel. Deze bestaan in verschillende kleur, maar het rendement is sterk afhankelijk van het gekozen type korrels. Deze manier van is minder brandveilig en geluidisolerend dan glaswol.
PUR-schuim
Als het gaat om het vochtwerend maken, dan is PUR-schuim het beste materiaal, maar is niet echt goed voor de gezondheid en daarbij ook niet echt milieuvriendelijk, omdat het moeilijk te recycleren is.
Steenwol
Steenwol is gelijkbaar met glaswol, maar heeft als nadeel dat allerlei ongedierte zich er in nestelt en het materiaal op eet. Deze gaan wel dood, maar weg is weg.
Wanneer u zich gaat verdiepen in de materie van het isoleren, dan kijkt u het beste op http://www.isolatie-vlaanderen.be./
on Jan 13, 2016 | Insulation
Ons batterij gaan snel op dus ik wil weten wat ik er aan kan doen.Ik verwacht een antwoord en .Ik weet niet hoe je geluid aan zetten om geluiden te horen bij vidios .En daarom wil ik hulp van je jullie...
Vergewe die Google vertaling. Digitale kameras moet slegs gebruik word metherlaaibare batterye NiMH. Hou in gedagte dit sal jou geld spaar oor besteebarebatterye, en hulle sal die laaste vir ten minste 100 foto's per aanklag (en waarskynlikbaie, baie meer). Jy sal baie tevrede met hul prestasie en kan klap jouself vir nie te koop gouer. Wanneer by die winkel, kyk op die pakket vir 'n krag gradering van ten minste 2500 mah.
Jun 04, 2011 | HP Photosmart M407 Digital Camera
Waste ink near full
I'm having the same problem. Lots of solution for resetting the printer, but none of them helping me to lead me to the absorber itself inside the printer. It seems to be a lot of work and disassembling half of the printer! Looking on internet I haven't found any answer yet.
As I am living in The Nehterlands I'm looking for solutions in Dutch. One solutions discribes disassembling another Canon printer. This could possibly help. I'll paste the text below. It's dutch, so you'll have to translate it.
Wishing you succes with this matter!
Dutch text:
Wat te doen bij de melding 'Afvalinkt bijna vol'?
Onderstaand verhaal geldt voor de Canon SmartBase MPC200; voor andere Canon
printers geldt ongeveer hetzelfde, met uitzondering van de reset-procedure (zie
hieronder).
Oorzaak
Onderin de printer bevindt zich een langwerpig, dik vloeiblad (een soort spons van
vilt). De overtollige inkt, bijv. de inkt die gebruikt wordt bij het reinigen van de
koppen, wordt afgevoerd naar deze spons. Als deze spons bijna verzadigd is,
verschijnt bovenstaande melding. Dat is ook nodig, want als je gewoon door zou
kunnen gaan, zou de spons geen inkt meer opnemen, en op een bepaald moment zou
je merken, dat de printer zou gaan 'lekken'. Geloof me, dat wil je niet meemaken.
Printerinkt is gemeen spul!
Canon
Het lastige is alleen, dat Canon nogal moeilijk doet over deze melding. Zij hebben
maar één oplossing: opsturen en het probleem door hen laten verhelpen. Kosten: ruim
€ 100,-!!! Toen ik dat van de telefonische helpdesk hoorde, reageerde ik met: "Dan
kan ik beter een nieuwe printer kopen!" De telefoniste was dat eigenlijk wel met mee
eens.
Zoeken
Vervolgens ben ik gaan zoeken op het internet. Wat je daar niet kunt vinden, bestaat
niet, tenslotte... Toen merkte ik al snel dat ik niet de enige was met dit probleem.
Iedere eigenaar van een Canon-printer krijgt er na verloop van tijd mee te maken.
Helaas was er geen kant-en-klare oplossing voor mijn printer, maar door de
beschrijving bij andere printers kreeg ik wel een idee over de oorzaak van het
probleem en wat ik eraan zou kunnen doen.
Oplossing
Over de oorzaak heb ik al geschreven. Over de oplossing gaat het nu. Die gaat in twee
stappen:
1. De vilten spons schoonmaken.
2. De printer resetten.
Dit is een vies werkje. Doe een schort om en gebruik huishoudhandschoenen! Inkt in
je kleren gaat er niet meer uit en op je handen duurt het een hele tijd!
De spons ligt helemaal op de bodemplaat onderin de printer. Je moet dus een beetje
handigheid hebben en niet bang zijn om een schroevendraaier te gebruiken.
Schroef eerst de beide zijkanten van de printer los. Die zitten elk met twee schroeven
vast (één aan de voorkant en één aan de achterkant).
Verwijder dan het toppaneel (met de scanplaat). Die zit vast met twee schroeven aan
de achterkant en drie aan de voorkant (deze drie zitten aan de onderkant van het
bedieningspaneel). Let op: zodra je het toppaneel verwijdert, merk je dat die op drie
plekken vastzit. Op één plek met een schroef (gewoon losdraaien) en op twee plekken
aan de elektronica. Trek die twee punten voorzichtig los. Je kunt het toppaneel nu
opzij leggen.
Dan moet je de printplaat verwijderen. Maak eerst alle 'draden' voorzichtig los. Kijk
goed hoe het vast zat, om het later weer te kunnen bevestigen. Maak dan de printplaat
los (4 schroeven). Verwijder daarna ook de metalen plaat, waarop de printplaat vast
zat.
Je bent er nu bijna. Het bovenste deel van de kast (voor zover die er nu nog staat) is
op de vier hoeken met schroeven bevestigd op het onderste deel van de kast. Je moet
misschien wel even zoeken, want ze zitten diep weggezakt. Schroef ze los.
De bovenkant en de onderkant zijn nu los van elkaar, maar nog wel met draden en
elektronica aan elkaar verbonden. Maak die verbinding niet los, dat is niet nodig.
Doe nu het schort om en de handschoenen aan!!
Je kunt nu bij de bodem van de kast komen. Daar zie je de spons, die zwart is van de
afvalinkt. Kijk eerst hoe de spons erin zit, voordat je die eruit haalt.
Maak de spons voorzichtig schoon. Niet wringen en zo, alleen uitspoelen en eventueel
induwen om de inkt en het water eruit te halen. Ga een flinke poos door, totdat er
alleen nog schoon water uit de spons komt.
Hang de spons een paar uur te drogen in de zon. Gebruik daarna een föhn om ook het
laatste beetje vocht eruit te halen, zodat de spons weer kurkdroog op zijn plek gelegd
kan worden.
Zet de zaak nu weer in elkaar. (Als je het net zo doet als ik, houd je twee schroefjes
over, maar mijn printer doet het nog steeds prima. )
1a. Niet schoonmaken maar bestellen...
Sinds kort weet ik dat je de spons ook kunt bestellen. Dat scheelt een boel pruts- en
schoonmaakwerk.
Je kunt de vilten spons, die uit 2 onderdelen bestaat, bestellen bij ETB (Electronic
Trading Benelux).
Bel naar 0165-850500 en bestel de volgende artikelen:
HC1-0795-000
QA4-0213-000
Toen ik ze bestelde (in maart 2006) waren de kosten voor deze 2 onderdelen samen
maar E 1,04!!
Deze prijs was wel exclusief btw en verzendkosten. Maar omdat ik het samen met
andere producten bestelde, had ik daar geen last van.
Als je nu de printer weer aanzet, kun je merken hoe dom het apparaat is. Hij heeft niet
in de gaten dat de spons weer schoon en leeg is. Dat moet hem nog verteld worden.
Op het internet kon ik daar geen geschikte procedure voor vinden, dus ben ik maar zo
brutaal geweest om Canon op te bellen. Eerst deden ze afwerend (ik moest de printer
opsturen), maar toen ik vertelde, dat ik het grootste deel van het werk zelf al gedaan
had, kreeg ik een technicus aan de lijn, die me stapsgewijs uitlegde wat ik moest doen.
De stappen laat ik hieronder volgen:
1. Zet de printer aan
2. Druk op de (langwerpige) menuknop
3. Druk op de meest linkse ronde knop (Copy)
4. Druk op de ronde knop rechts daarvan (Scan)
5. Druk twee keer op de meest linkse ronde knop (Copy)
6. Druk op het min-symbool (links van OK); het scherm zegt nu: 'Test mode'
7. Druk op OK
8. Blader met het plus-symbool (rechts van OK) tot het scherm zegt: '#8 Printer
Test'.
9. Druk op OK
10. In het scherm staat nu: '8: Printer Test' en daaronder: '- 8 - 2 +'
11. Druk 1x op het plus-symbool; in het scherm staat dan: '- 8 - 3 +'
12. Druk op OK
13. In het scherm staat nu: '[0]: Ink Count'
14. Druk op OK
15. Druk op de knipperende oranje knop om die uit te laten gaan.
16. Mogelijk werkt dat niet. Trek dan de stekker uit het stopcontact.
17. Wacht even. Doe de printer weer aan.
18. Als het goed is, ben je nu bevrijd van de irritante melding over afvalinkt.
Succes!!
Nov 04, 2010 | Canon PIXMA MP750 All-In-One InkJet...
Ipod nano is ingesteld op audio auto radio kan deze wel dedienen maar speeld geen geluid af
iPod Nano is aangesloten op de Pioneer Car CD Player, je ziet het menu van de iPod er wel op. Maar de Pioneer Car CD Player speelt de muziek van de iPod niet af, maar de muziek van de Radio wel.
Dus wat kan ik er aan doen zodat het geluid wel wordt afgespeeld.
Met vriendelijk groet,
Cees Sins
Dec 13, 2009 | Pioneer Car Audio & Video
Ik ben in het bezit van een LG 20170 LHR4400, Home Theatre System. De cd's kunnen wel, maar de dvd's kunnen niet meer bekeken worden. Er verschijnt een schermpje met "Unknown disc", vervolgens wordt de...
I don't have a solution for my problem with my dvd-player. First I'll try to clean the reading-laser with a special dvd-cleanerset. Than I shall see what happens, perhaps the problem has gone.
Thanks for your reaction.
Nov 27, 2009 | Jensen VM9510 Car DVD Player
He' Hallo Ik heb een motor suzuki gs 750
www.thegsresources.com
great website for these bikes
Sep 17, 2009 | 1979 Suzuki GS 750 E
Lens van mijn Ricoh Caplio R 6 gaat niet meer in of uit
Hoi Van de caplio R6 zijn geen onderdelen leverbaar, de camer moet worden aangeboden aan Ricoh Nederland ze zullen je een website aangeven waar je de gegevens kunt opzetten en daarna pas de camera kan opsturen aan hun servicecenter
Groet,
Rob Rotronica
Apr 15, 2009 | Ricoh Caplio R6 Digital Camera
Siemens Gigaset 4000 Classic Cordless Expansion Handset Logo
280 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
