Question about Gateway 500GR PC Desktop
My computer turns off and when restarted says it was shut down due to thermal over heat. Both fans are working.
    President:
  • 2,653 Answers
I would take the unit outside and give it a thorough cleaning, lots of dust accumulates on the cpu fan and heatsink ;)
Afterwards if its working stable I would update the bios firmware, just make sure it doesn't overheat during the upgrade, it's critical!
Posted on Nov 13, 2010
Laptop switches off after 5 minutes
Try removing all plates and covers and restart
Also check where you soldered for any excess solder touching anywhere on m/board or case
It is a heat problem you could try a packet of frozen food suitably covered to see if it works longer
Feb 28, 2017 | HP Computers & Internet
Fan not working
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Feb 18, 2013 | Acer Aspire AX3960U4102 PTSFF02027 Desktop...
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
I have an HP Pavilion dv6 1030us, and I replaced the fan due it going bad, and also the touchpad, and everything worked fine, till I started trying to turn it on, it gets all the way up, and i can enter my...
When you replaced the fan, did you clean off the old thermal compound from the processor and other chips and replace it with a fresh layer? It sounds like your computer is shutting down due to heat. Also, did you remember to plug the new fan into its connector on the motherboard? I know it sounds silly, but sometimes people forget, or don't seat the plug all the way and it comes loose.
There's also the possibility that the motherboard suffered some heat damage before you replaced the fan, but check the other things first.
Jul 09, 2011 | HP Pavilion dv6-1030us Notebook
Dell laptop every once in a while shuts down completely, im wondering if its over heating.
Restart the computer in safe mode (Press F8 key when you restart computer and see the dell log untill you see the Advanced boot options, choose safe mode using your up and down arrow key and hit enter).
you system will load the basic windows drivers and will not connect to internet.
Please keep your system on and work with it for some time and test it. Even in this mode if your computer restarts then its definitely due to heat, else its due to application errors or driver errors.
Dec 24, 2010 | Dell (6F858) Cooling Fan
Why my computer automatically shut down eventhough it working 10 to 15 mins?every time i restart it will shut down again...what is the cause? do i need to replace the new one(motherboard)?
You could have a problem with your OS, it could be viruses, or other things.
It could also be a force shut down by your motherboard. Before you replace the motherboard, check to see if you computer might be over heating. Touch the heatsink on your CPU/Motherboard. Feel if it is too Hot or Cold. You only want it to be warm.
Mar 08, 2010 | EliteGroup P4VMM2 Motherboard
Computor shuts down. screen goes to black. turn back on and get siren sound and screen says shut down due to thermal event. hit F4 to resume. had same problem a couple years ago and they replaced fan
try applying new cooling pest between cpu heatsink and cpu. Heat from cpu surface should be quickly transferred to heat sink. Either coolent problem or heatsink doesnot properly fit on cpu. But be carefull, you need an 'EXPERT' to do this, or you end up damaging everything.
Jul 30, 2009 | Computers & Internet
Fan Malfunction??
Sounds like a heat issue, pop the side of your case open and turn on the PC, are there fans not moving? Take a close look at your processor fan if there is one.
Jul 10, 2008 | Dell Dimension B110 PC Desktop
Gateway 500GR PC Desktop Logo
44 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
