Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
We have a Phillips rear projection tv, about 9 years old. The color has been getting progressively worse over time. Dark scenes are almost impossible to see. It almost seems that only blue and red are the only distinguishable colors. Everything else just kind of blends in. I cleaned inside the tv last year. I also tried resetting the factory color settings. Any suggestions?
  • Philips Master
  • 8,457 Answers
Tv have halo pictures and dulls colors?Yes,the tv have bad Coolant chemicals on those colors guns R,G,B CRTS tv Tubes.Must replaced those CRTS Coolant chemicals on those CRTS tv tubes.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced those CRTS tv Tubes coolant chemicals.
Posted on Nov 13, 2010
Our 57H81 is about 10 years old and we can hardly see the picture on tv/movies especially - when a dark scene is shown. Do we need to perform maintenance or change out the projection lights to get the...
You can try cleaning the lens/mirrors of the set with a lint free cloth and a cleaning liquid made for cleaning glass. The dark image can sometimes be caused due to dust on these parts. If that does not work then I am afraid that you need to purchase replacement CRTs(the three tubes at the back of the set). Each of them produce one color - Red, Green and Blue and all 3 have to be replaced to resolve the problem, unless you can visually identify a malfunction with one of the tubes(If one of tubes is a lot dimmer than the other 2).
Sep 18, 2011 | Toshiba 57H81 57" Rear Projection...
Picture is very blue, especially in dark scenes.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 21, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Big red circle in the middle of the picture
Your light engine is bad and needs replaced. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 30, 2010 | Hitachi 51F59 51" HDTV Projection...
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each color...one is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Pt47wx49 panasonic rear projection tv has very dark tv scenes
Has this problem been getting progressively worse? I would suggest cleaning the CRT's inside the tv with lcd screen cleaner or something similar. Make sure the tv is unplugged, all you have to do is undo some screws on the back to gain access to the inside of the cabinet. Hopefully that's all it is. Your set has no lamp if it is a Panasonic Pt47wx49.
Nov 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Philips 50" rear projection- Washed out picture.
You need to change the CRT Fluid. This is a common problem on the  older projection TV sets.
You can get the fluid and instructions on how to change it from www.TvRepairKits.com.
Dec 19, 2008 | Philips 9P5034C 50" Rear Projection...
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
