Question about Dremel Variable - Speed Multipro Rotary Tool 395
Coupler on shaft is broken off on the end. This is Dremel 395 type 3. Where can I get the part?
  • 7,733 Answers
Look at eReplacementParts.com and the parts diagrams,
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 13, 2010
Flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
Nov 06, 2012 | Dremel Variable - Speed Multipro Rotary...
I took apart my Dremel 395 Type 3 and the spring popped out for the shaft lock. Where does the spring attach to?
It doesn't attach anywhere, that's why it popped out. It should just fit in a recess, pushing the lock button outward.
Sep 10, 2011 | Dremel Variable - Speed Multipro Rotary...
I need part # 2615294309 coupler for a 395 Dremel tool
I had the same problem - couldn't get the part (plastic coupler between the spline drive shafts). I purchased a waterproof **** Splice (GB-AMT-5126 12-10 gauge -- used for electrical wire splicing -- got it at Home Depot). Clipped off about 3/8" on each end with diagonal cutters and attached it to the shafts. The steel ring in the middle of the **** Splice connector provides good structural support to the connection. Works like a charm. Plus with a pack of 4 connectors, I have 3 in reserve.
May 24, 2010 | Dremel Variable - Speed Multipro Rotary...
Broken Dremmel tool spindle stop turning but motor runs
I called Dremmel tech support FOR FREE and they told me what was broken - flex coupling between shaft and spindle. Only Dremmel model 395 type 2 and 3 have these couplings. Mailed out repair kit yesterday.
Dec 23, 2009 | Dremel & Stylus Lithium Ion Cordless...
Dremel Model 395 Type 3 Plastic Drive Shaft Connection broke into pieces. Replacement needed.
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
Apr 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Nylon Coupler crscks when installing
I'll answer last question first. They might be cracking because they are in a bind and when turned on or inserted on the shaft there is too much pressure. Make sure the shafts are free of any debris from the original coupling, also check the bearings for wear or being so tight that they twist the coupling. Everything should move freely. And second I would recommend calling Dremel direct at 1-800-437-3635 for replacement parts. Hope this helps.
Dave
Dec 26, 2008 | Dremel Variable - Speed Multipro Rotary...
Coupling broke
I have a Dremel 395 Type 3. Motor works fine, shaft doesn't turn. Took it apart to find that the white plastic or nylon flex coupling on the shaft had crumbled and the spline driver, which fits directly over the motor end of the shaft was somewhat worn. I emailed Dremel and got an overnight reply listing the 2 parts I need and the cost: Coupling is $1.00 and the driver is $1.25. Placed order by phone: 1-800-437-3635. I ordered 2 of each in case future replacement is needed. Total bill came to $7.27 including Florida tax and shipping. Can't beat that. They said it would be in the mail by tonight. (Flex coupling number is 2615294309; spline driver is 2615294308.)
Rating Locked! (?) lexrehabtech has rated this solution as Helpful
Oct 26, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 Type 2
REFERENCE M/N: 395 - Type 3 - Dremel does not have the parts listing on their site for some reason. I actually have the original I saved from 1988!
The part number for the Nylon Coupler is:
Illustration Code Number: 5
Description: Flex Coupling
Part Number: 529430970
This is all from Drawing (Form) Number:5296074 10-88
Jun 15, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
406 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
