Question about Kitchen Ranges
I have a GE Talisman Royale oven that has just stopped working. The lights for the burners and oven come on, but non of the elements will heat at all.
  • 1462 Answers
SOURCE: fan oven element not working
getting a shock just means that live is connected. if no heat, that means that no neutral assuming element is ok. do you have a multimeter so you can check if live and neutral present at element? are you sure old element was faulty as it seems strange that putting in a new element did not cure problem i have a memory that there may be a fan fail stat mounted close to the element. worth a check
Posted on Apr 01, 2007
fridgetech
  • 473 Answers
SOURCE: GE Spectra XL 44 Gas Oven Bottom Heating Element Faulty
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 05, 2007
SOURCE: Blinking oven and heating Lights
for no reason the cleaning light went on, even though the oven was not on. The oven light and heating light were alternating each blinking 5 times. The door locked up, too. It seemed to think it was in a cleaning cycle. Any way, problem solved by throwing off the main breaker and all is working fine since... except now, for no reason the oven fan, not the exhaust fan, stays on all the time!
Posted on Jan 03, 2008
aborcass
  • 2651 Answers
SOURCE: heating element in GE Range Oven
get the model number and order the exact repacement bake element
Posted on Mar 10, 2008
SOURCE: GE P7 Oven 2 burners out on stove top
Purchased a new stove.
Posted on Dec 27, 2008
How do you operate the self cleaning option on a GE Talisman Royale Stove that's quite old
Before you try to run the self clean feature read this tip...
Mnay problems are cuased by the high heat of the self cleaning...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
Heatman101
Mar 12, 2010 | Frigidaire GLEB27S7A Electric Single Oven
Why would an electric oven stop working? I tested the element
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are theignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help. Repair and checking tips for surface burners.
Nov 16, 2009 | GE Kitchen Ranges
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
Ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Feb 25, 2009 | Ovens
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
Burners, oven will not heat, all lights work
Sounds like you are only getting 120 volts. All heating elements require 240 volts to operate. Start by taking the covers off the back of the range and looking for loose or burnt off wires. Look first at were the range cord connects onto the range. If all OK with range wires, check wires inside range receptacle (where the range cord plugs in) and also the connections on the household circuit breaker or fuses. If you use a meter to test for 240, you may see it, but if a connection is poor, it may not be good enough to supply the required power.
Oct 02, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE Oven Model JK1901BC
check power cord if oven light not working or burners then you have a power problem no there is no reset if you have power at the outlet then pull the range out take off the back cover where the power cord is and check there let me know we will go from there
Dec 30, 2007 | Ovens
Kitchen Ranges Logo
221 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
