Question about Poulan Garden
How to rewind spool on my McCulloch MT 700 weed eater
  • 8,197 Answers
On the link below page 11 to 13 vwill tell you how to wind the spool.
http://dl.owneriq.net/3/36e9171d-7ceb-ed84-213c-fc65a92614ec.pdf
Good Luck
Posted on Nov 13, 2010
Ryobi weed eater troubleshooting
Here is a video I found helpful.
https://www.youtube.com/watch?v=iMFUW6DJia0
Aug 19, 2014 | Garden
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Line installation
Hi bluemontel52...
Hi
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 03, 2011 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I need to replace wire on an electric weed eater auto feed 15 inch
Hi deanko1
Jul 01, 2011 | Homelite Garden
Mcculloch trimmac 250sl the spool at the end of the grass trimmer does not spin although everything else works fine. I think it's the angle gear that's broken but I don't know how to get to it....
on top of the head there is a star shaped bolt(middle of the head), remove bolt and rotate the spool you should see the gear turn, to remove the head from the shaft remove bolt/screw on the side of the shaft towards the top of the head, remove head and inspect the shaft, this should rotate when you pull to start the weed eater, if it does not then you will need to remove the top portion of the weed eater and inspect to see if the shaft is broken or not seeded inside the motor. Hope this helped Tim
Jun 07, 2011 | Garden
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
McCulloch mt 700 weed wacker,the weed wacker will not spin to cut the weeds
If the motor is running another possible solution is you have a broken drive shaft spring PN-753-04280 To check this remove the screw which holds the **** pipe to the motor and loosen the clamp. The **** pipe should pull right off the motor exposing the end of the drive shaft spring. Pull the end of the spring, if it comes out it is broken.
Jul 06, 2009 | Garden
LOST MY BOOK ON THE CORDLESS POWER GLIDE WEED EATER. i DON'T KNOW HOW TO CHANGE THE SPOOL.
attached is a scanned copy of the page of the booklet to change the spool; if this is not what you want, I also have scanned the page to show how to rewind the spool
Jun 12, 2009 | Ace Hardware Power Glide Cordless String...
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Weed eater spool fell off
the spool goes on first then a big spring and finally the cap and the screw thats all
May 24, 2009 | Garden
Garden Logo
380 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
