Question about Toshiba 32DF46 32" TV
My tvs picture keeps compressing into one line
    Brigadier General:
  • 8,909 Answers
If it goes to a horizontal line, you have a frame fault, usually caused by dry joints on the frame IC. Look around all IC's and components that are mounted on heat sinks as they are prone to poor soldering.
Likewise if it is a vertical line, dry joints on the scan coils can cause that as well as heavy components on the pcboard.
Hope that helps.
Posted on Nov 13, 2010
How to replace fuel line on a Mac 10-10
If its a Mac 10-10 it is old enough to need a thorough major component disassembly and service. Keep your smart phone handy and take a few dozen pictures as you disassemble each component until you get down to just the engine/clutch assembly. Use compressed air and possibly a spray can of carbuetor cleaner (follow all the safety instructions) to totally clean the impacted sawdust and oil from the clutch, magneto, cylinder and the removed components.
With the new replacement fuel line and impulse line on hand, start the reassembly referring to the pictures in reverse order....
Sep 25, 2015 | Garden
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
Why has my sanyo flat screen television only got coloured horizontal lines across the screen?
That might be an issue with the TVs picture tube if it was not one of the LED or LCD TVs. Please get a technician changed it. If it was any one of the LCD or LED TVs, then it would be more expensive than you expect.
Jul 20, 2014 | Sanyo Televison & Video
Tonight my boy friend accidentally knocked over the tv. the bottom metal base came off and there are multiple bands of horizontally in different colors that keep coming up on the picture. You can see the...
Sorry this tv have damages cracks on the LCD screen panel already.Tv have to replace the whole LCD screen panel to repair it.As the LCD screen panel are 90% important to the tv and very limited in production.Buy and replaced only by the tvs corporations only,cost the same as a new tv.This tv now not worth as a whole tv anymore,all these tvs in this situation alway end up as salvages tvs as for spare electronic PCB boards for other tvs only.Time to buy a new tv make the boy friend pay some money too,because he cause the accident.
Jun 05, 2011 | Vizio VS420LF1A TV
Son got a hold of the remote and now the picture is larger and doesn't fit the screen- I don't know how to get it back to normal. Help!
hi,
your tvs zoom function is in on position. to make it of just press the picture size button on your tvs remote. every time press the picture size button different mode will seected, like zoom ,compression ,normal.
select the normal mode.
be sure that the selector switch in the side of the remote should be at TV
ok
Jan 27, 2011 | Toshiba 32HF73 32" TV
Vertical black lines appear intermitently
Does the line appear on just one input(cable,hdmi,video1,video2,ect) or on all of them? The reason why I ask is it may be just an issue with one input setting on the television and you may be able to use a different input for a temporary fix of the problem. Plasma telivisions run very hot and it may be overheating. Try using a small mountable fan above the TV pointed into the back heat vents and see if keeping it cooler keeps the issue from happening. These TVs are repairable but usually cost more to repair than what it is worth due to plasma TVs are very in-expensive now.
Sep 04, 2009 | Maxent MX-42V1 42 in. Plasma Television
Verticle hold transistor?
The vertical hold keeps a normal picture from rolling either up or down. You don't have a normal picture (raster) here.
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace.
Good Luck!
- Jim
Jan 24, 2008 | Televison & Video
Sanyo DS31520 31 Picture problem
hi there, it is worth for fixing it, cheaper than replacing it. you have a vertical section problem. look for a quilified service personnel for it to fix. ty
Nov 12, 2007 | Sanyo DS31520 31" TV
Toshiba 32DF46 32" TV Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
