Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
My Moultrie camera turns itself off. i have set it numerous times and when i go back to check it for pictures, the power is off. the batteries are showing 99% so its not the batteries??
Don't know what causes it, but I have 2 cams that are doing the same thing. Batteries are 95%. Don't know if has anything to do with cold weather. Haven't had this problem in the past.
Posted on Dec 31, 2010
My Moultrie M880 game camera is set to take 3 pictures, so once I place the SD card in turn on and I have in a area with no moving grass or limbs the camera will take pictures non stop. I will check i
Post subject: Re: M880 problem Solved .... icon_post_target.gifPosted: Tue May 27, 2014 3:48 pm icon_user_offline.gif
First of all, ONLY USE THE STANDARD SPEED SD CARD THAT MOULTRIE ADVISES.
Second, DO NOT TAKE THE CARD OUT & USE A READER WHILE LEAVING THE CAMERA MOUNTED (this will lock up the camera).
Third when using a brand new standard speed sd card, DO NOT FORMAT THE SD CARD IN ANYTHING OTHER THAN THE CAMERA.
One could clear the camera by reseating the battery (take the battery out & put it back in). The reset button (up inside) is not always necessary for this.
You probably got a different speed card to somehow work & the camera malfunctioned. Bear in mind the aforementioned advice.
Nov 29, 2014 | Moultrie Cameras
Resetting the Moultrie A-5 Game Camera
HARD RESET TAKE OUT BATTERIES SD CARD PUSH THE ON OFF BUTTON FOR ABOUT 5 SECONDS LEFT EVERYTHING OUT FOR 2-5 MINUTES. THEN PUT THE BATTERY BACK IN TURN THE CAMERA ON IT SHOULD SAY NO CARD. THEN TURN IT OFF THEN PUT THE SD CARD BACK AND TRY IT IN THE DARK AREA TO SEE IF THE FLASH WILL GO OFF. IF THAT DOESN'T WORK WILL NEED TO SEND IT IN FOR REPAIRS.
Nov 07, 2013 | Moultrie A-5 Game Camera
My pictures at night are nothing but a black picture
HARD RESET TAKE OUT BATTERIES AND SD CARD, TURN IT TO THE ON POSITION FOR ABOUT 2-3 MINUTES WITH NOTHING IN IT. AFTER 2-3 MIN PUT BATTERIES BACK IN WHILE WITH THE ON POSITION IT SHOULD SAY NO CARD. ONCE IT SAYS THAT TURN OFF THE CAMERA PUT THE SD CARD BACK IN TURN THE CAMERA BACK ON AND TEST IN THE DARK. IF THAT DOESN'T WORK SEND IT IN FOR REPAIRS TO MOULTRIE.
Nov 07, 2013 | Moultrie Game Spy D-333 Game Camera
My camera goes off after 2 minutes the screen goes blink and doesn't take pictures you have to cut it off then turn it back on if no motion it goes back off don't have instructions anymore what shall i do
Try cleaning the battery contacts and the battery itself with a q tip dampened (not wet) with 91% rubbing alcohol. Then, in the main menu click to set all values back to Factory default.
Oct 21, 2013 | Moultrie Feeders D55irxt Game Spy Camera
Hi, when I click on the button to view pictures the camera switches itself off. Also if I click on the tool box menu the camera switches itself off. Also if I connect to my PC it doesn't see the camera -...
Have you checked the batteries on the camera? Weak batteries will shut the camera off any time ther is a call for power that exceeds the charge left in the battery.If after you change or charge the battery and you are still having this issue let me know and we can go from there.
Please use Sony Cyber-shot batteries for DSC-H2 model camera
If your camera keeps shutting down and not allowing any pictures to be taken, use the 3 pixel setting. It may allow you to get at least some use out of the camera. After reading numerous reviews on this unit and comparing the performance of mine to that of a friend who also has it, I have to say that SONY made a slew of defective cameras and this should have been a recall. Some cameras seem to work fine, thus the good reviews. Others, and there are many many of these, shut down unexpectedly, won't work well on the 5 mega pixel setting, take terrible pictures (especially in low light) and generally aren't worth the money you paid for them.
What I soon learned was that it was running low on battery power and needed to be off most of the time or you would go through batteries like butter. Even when the camera is off and loaded with new cells it will quickly deplete itself. So you have to turn the thing off if you aren't about to shoot...this makes catching that special shot almost impossible, especially since when you do turn it on you then have to wait and wait and wait for the shutter to snap. Forget anything with low light
Dec 26, 2010 | Sony Cyber-Shot DSC-WX5 Digital Camera
My camera will turn itself off. it has been off the last three times i checked it. It takes less pictures each time before it turns off. Why is if turning itself off?
well its a battery fault,,,, its getting past its best so wont hold a full charge,
thats how we all get when we grow old???????????????? in short bursts only
Dec 01, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie DGS160 Game Camera Error 20000
Forget calling Moultrie...I think their answering system is permantly set for "off-hour" times...you may have to e-mail them several times be fore (after4-5 days they get back to you.
You're error should read error"0200000"...flash error or flash charging...getting this during system diagnosis probably is that you failed to cover sensor during ck.
I f this is a constant error...turn cam on; remove batteries; turn system off; insert batteries and try again. .
Oct 03, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My Moultrie 140 Camera does not take pictures in the field. When I run diagnostics I get the error code 020000. Can you tell me what is wrong?
Flash error....try removing bats with power on; turn power off; reinstall bats; turn power back on...run system diagnosis...FOLLOW SCREEN INSTUCTIONS
Sep 27, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie D 4.0 continous exposures
..your not in "Interval Mode", are you?? IF your cam is set to start an "interval @ say 2400hrs( midnight) and to take pics every 1 min./5 min/;ect., IT WILL!
Make sure you're in "AUTO MODE"...It's easy to accidently hit the mode switch when moving the power switch from off to on..(I didn't find this out by reading a book...)
Feb 22, 2009 | Moultrie MFH-DGS-100 Digital Camera
Locked up
On my Moultrie MFG-DGW 2.1, I was unable to change settings etc... It seemed to be locked at the Date/Time screen. I powered off the unit, removed the memory card. Turned on the unit. Then I could change the settings. I made my changes, powered the unit off, reinserted the memory card, turned the unit back on and it read the card and I could make changes too. This happens from time to time. I just have to follow those steps to clear it.
Hope that helps.
Oct 28, 2008 | Moultrie MFH-DGS-100V2 Digital Camera
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
507 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
