Visionquest LCD 22WSHD, it will display briefly then goes blank (but the power led still shows as working). If I press the power and reopen it, it will breifly display then go blank. (either in dos/bios or in windows). I can do that seemingly forever...But would prefer to repair it... What part needs to be repaired/replaced? and is there a service manual out there?
  • 11,361 Answers
Please read my guide then you will get more understanding on what to look for inside the monitor.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 14, 2010
Led will not show.comes on for a second then blank
James, sounds like a power supply issue.links below to shed some light on your issue.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
How to Fix LCD Monitor Power Problem
MOST COMMON REPAIR FOR LCD NO POWER
Fix Malfunctioning LCD Power Supply
How To Test Computer Monitor That Won Display Or Is Not Working
Feb 15, 2016 | Computers & Internet
Lg42 lcd comes on and and displays menu and no signal bar if i select a source input it will show briefly until tv brightens and then goes blank but sound is still present
Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS].In such cases, the power supply board might need replacement.
Sep 16, 2015 | Televison & Video
LCD display failure
First place to check will be the power supply section, look for bad caps with bulging top first, post back what you see so we can guide you more, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Inverter/pwr: http://www.lcdrepair.us/e193fpc-inverter-power.html
Feb 17, 2010 | Relisys RLT1720 17" LCD Monitor
Computer screen goes into "digital power saving mode"
You should be able to adjust the settings on the monitor to prevent it from going into power save mode, or at least to delay how long it takes before it goes into power save mode. Press the menu button and look for settings that might disable or change power save mode.
Also, does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your newer monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PC's video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG L1915S 19" LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Computers & Internet Logo
349 people viewed this question
David Payne
David Payne
