Question about Toshiba 43HX71 43" Rear Projection Television
Red blinking light
I don't get a picture just a blinking light. Any suggestions?
  • Anonymous Aug 24, 2008
    Having the same problem with the blinking light what type of trouble shooting needs to be done, power cord change?
  • Toshiba Master
  • 8,617 Answers
Does the audi work? If not and the LED is blinking you have a problem with the power supply that will need to be trouble shooted.
Posted on Jun 18, 2008
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic viera no picture, power indicator light flashing red
l would suggest if knew the model number which is not indicated an answer ===red blinking is usually in a sequence like ten blinks, pause and indicates an error code.
Apr 08, 2012 | Panasonic Televison & Video
Tv will not come on. Red light blinking on bottom left front. Red light blinks 7 times
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.comj
Nov 01, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
My 42 inch Panasonic Viera TC P42U1 was purchased in 2009. The picture was really nice and working fine. One day last week the TV stopped working. The only thing that the TV will do now is blink a red...
This is actually(And Sadly) an extremely common problem with the Vieras. The number of times it blinks is a fault code. 7 and 10 blinks are typically board failures inside of the unit usually being the power supply. It can be other things like a clogged fan freaking it out etc. If you search google you will see many cases of this problem and what each # of blinking lights indicates.
Things you can try at home are:
Unplug the unit for 20ish minutes. Sometimes this brings it back.
Did you install something else on the circuit? If you put for example a window air conditioner in place or something that is drawing alot of power it will not let the TV itself have enough power to run.
Sometimes if you are handy and have some soldering skill and skill using a multimeter you can check the capacitors and other components in the rectifying and filtering stages of the power board and replace them if they are bad for cheap. Capacitors would be the easy one to spot because they swell and look terrible when they go out. DON'T DO THIS IF YOU DON'T KNOW HOW TO WORK ON ELECTRONICS. OR DON'T FEEL COMFORTABLE. THERE ARE SOME DANGERS INVOLVED.
Otherwise if you have 7 or 10 blinks at a time it will need service.
Jun 07, 2011 | Televison & Video
I have an akai 27 lcd tv which shut down while watching. No sound no picture but the power switch is flashing red.I don;t know if it is a power supply problem or a burnt out backlight.I haven't opened the...
I would suggest to start by measuring the voltages from the power supply to the main/back light circuitry. If the voltages are low or jumping up and down, that means a defective power supply.
If the red light is blinking, the power supply has a shorted component.
Let me know if you need further assistance.
Sep 05, 2008 | Akai Televison & Video
TH-42PX80U
i have the same problem but i have 11 blinks
Aug 13, 2008 | Panasonic TH-42PX60U Television
No Picture
i have the same problem, differnt tv.
Blinking Code: LD740
it's for a 42w34 lg/zenith.
im thinkin power board, or Zsus..
Dec 10, 2007 | Acer AL2416W 24 in. LCD Television
Blinking Red Light
just push the button one or two more times at will take a picture while the light is blinking red.
Dec 05, 2007 | Vivitar ViviCam 3705 Digital Camera
Toshiba 43HX71 43" Rear Projection Television Logo
132 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
