Question about Bose Acoustimass 16 Speaker
Bose acoustimas double cube speakerposted by godzulu on 06/17/2008
Wanted to let you know that i posted pics of this speaker
  • godzulu
    godzulu Jun 18, 2008
    Will give it a try. Thanks - and will let you know and send pics
  • godzulu
    godzulu Jun 19, 2008
    I rotated the 'clip' 45 degrees clockwise from your photo and they fell into place. The hole on the clip was aligned with the red/black terminal holes on back of speaker. Was not sure how you wanted to place the springs, so I placed them above the clips perpendicular in relation to the standing speaker ( just resting on top. I dont know if that is correct or not? The speaker wire will go thru the holes but there is nothing to hold the wire in place. Fry's electronics have the same speakers connected but their wire seem to be held in place. Of course they would not let me take them off the stands. Suggestions welcome...thanks for the help.
    Brigadier General:
  • 3,614 Answers
Ok.. i will check it there...
thanks..
Posted on Jun 18, 2008
  • micromaster
    micromaster Jun 18, 2008
    can you take picture on focus to the cover, to the spring, to the metal, & to the inside of the speaker
  • micromaster
    try this orientation
How to put together a double cube bose speaker
The Bose speakers with the cubes and bass module are all interconnected with a proprietary cable available from Bose, if lost you get a replacement by called 1-800-444-BOSE.
When you connect the speakers all wires run from the receiver to the base module first, then out to each of the speakers. All terminals on the bass module are labeled.
The Bose cubes are all identical and can be used in the front or back positions.
Try to keep them at ear level or aimed at the listening position for best sound.
May 17, 2011 | Bose Acoustimass 15 System
what the exact model # of the unit..?
Jun 17, 2008 | Bose Acoustimass 16 Speaker
Bose acoustimas speaker output jacks not working
try to trace your problem inside the main circuitry of the jacks ( open it and see on the solder side of the Printed circuit board(where all the electronic components and soldered/welded if there are loose connections (small cracks... use magnifying glass if you have one) then solder them.
also check for the transistor amplifiers and output capacitors....
check also for the connectivity of all wirings!
Nov 17, 2007 | Tannoy Sensys 7 Speaker
I have a pair of redline bose cube speakers and an acoustimas. I don't have cable for the connection. I would appreciate if someone help me showing diagram and which cable I should use it. Thanks
You can make a serial cable for it. All you need is a 15-pin d-type female connector and a bunch of speaker wire. Solder the speaker wire as shown in my diagram.
Sep 22, 2009 | Bose Acoustimass 10 III System
Bose Lifestyle 5 speakers(woofer + 5 double cubes)
I repaired the contol unit per instructions from a post at FixYa.
Sep 11, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Cube speakers w/ no subwoofer
I have the acoustimas systrem and the speakers do need the sb. That's the heart of the system.
I dropped my two front cubes and neither work. If you would be willing to sell yours at a reasonable price I would be willing to buy.
Please contact Bose customer support and I believe they will tell yiou the same thing.
Please let me know.
May 02, 2009 | Bose Acoustimass 5 III System
I WANT TO SUBSTITUTE 191 SPEAKERS FOR DOUBLE-CUBES WITH MY LIFESTYLE V20 SYSTEM
Yes, there should be no issues at all with just using different speakers. Just connect the 191's as you would the cubes and you should be fine. Please rate my answer, thanks.
Apr 28, 2009 | Bose Virtually Invisible 191 Main / Stereo...
Replacement speaker (upper) for Bose double Cube.
try a music specialty store or radio shack if you want to only replace the small speakers inside the cubes. If you want to replace the whole cube, there are others out there. Look on ebay and or amazon I think the brand is JA Audio. A knock off of the bose cubes that can be used as stand alone speakers without the module.
Jan 05, 2009 | Bose Acoustimass 15 System
Audio problem - Bose Acoustimas
Go into the parameters setting for your receiver and make sure that your levels are at least matching all outputs. If this is not the case, suspect wiring or a problem with the amplifier. Oh, and last but not least, make sure that the receiver has at least the "speaker A" option switched on...accordianman
Jan 27, 2008 | Bose Cinemate Digital Home Theater System...
Bose Acoustimass  16 Speaker Logo
122 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
