Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - Black-on-Black
Right front burner ignites normally then suddenly goes to very low flame. i remove the disk on it and run a fine wire through the hole where gas comes out. the flame is normal fora few minutes then shrinks again. when cooled the flame will light normally without reaming for about 2 minutes then goes back to low.
  • 1 more comment
  • lizzyzxl Nov 15, 2010
    please explain why it's so complex. how many steps, what equipment? is there soldering to be done?
    also , how much do you estimate 1 parts, 2, labor, 3 time involved for a repairman( i know it would take a novice like me longer).
  • lizzyzxl Nov 17, 2010
    i have asked repeatedly to be informed that my "membership" be cancelled. i have received no reply. please tell me how to cancel membership. i do not feel i got my moneys worth.
  • 11,800 Answers
The jet you were cleaning with the wire is not the problem here - if it would have been clogged by dirt the flame would have been low always.
This gas range has a flameout protection - a bimetal sensor that should cut off the gas when the flame extinguishes. In your case the sensor on that burner is malfunctioning - when it heats up it cuts off the gas instead of opening the control valve. You will have to replace it . For that i strongly advice you to call a certified repairman - it's a complex job on which you cannot allow leaks.
Posted on Nov 14, 2010
  • Azrael SRL Nov 15, 2010
    First you need to take the button - easy, then to remove the burner - relatively easy, then to disconnect the gas line - complicated, tiny space to move it around must be careful not to bend the pipes or damage the threaded connectors, finally to remove the safety - very complicated,you will need to wiggle the wires thru the entire top plate to remove them. In total it's an about 1.5 hours job. The parts will cost you about $100, for the labor it all depends on how much a certified repairman would charge you per hour.
  • Azrael SRL Nov 17, 2010
    send an email to support@fixya.com.
Single wire igniter that sparks the oven on but flame goes out after a few seconds. Does the igniter control gas valve?
Its the other way around the valve controls the igniter so to speak
GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 23, 2015 | Ovens
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
Low flame on left front burners high flame onright front burnners
That is food/grease buildup. Clean the holes. TURN OFF GAS to stove, then just clean the holes in the burners with a soft wire brush. Then turn gas back on and immediately relight pilot lights. If that sounds scary, call your gas company, they might come out and help.
Dec 09, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
Right stove top burners won't ignite
Your right side burners probably have small vertical lighting holes that are clogged where the pilot lights the burner. Use a sewing needle to poke each hole clean. While you're at it, poke clean the horizontal burner holes just to make sure they are not clogged either. Are there also little tunnels from the burners to each pilot flame? Make sure those are clean inside and attached properly on each end. The pilot flame should be approx 3/8" tall. Compare the working pilot flame to the non-working pilot flames and adjust as necessary. Each pilot has a small aluminum tubing running to it, the adjustment screw will be on this tube. You'll just need a small flat head screw driver to turn it counter-clockwise to increase flame. Hope this helps. Let us know if we can be of further assistance. Douglas
Jun 05, 2010 | Amana ACF3325 Gas Kitchen Range
Whirlpool stove top- two problems. 1) burner is not burning hot, low flame 2) igniter on different burner doesnt work, no spark at that burner.
Hi
If the burner is not burning hot, and there is a low flame then this is often a pressure regulator problem. Most often the regulator is found where the gas line enters the gas range. I have a picture of what the flame characteristics should look like. If the igniter on different burner doesn’t work, and there is no spark at that burner then you will have to check the same items as mentioned above. This is a typical spark module wire diagram.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | Whirlpool GLT3615 Gas Cooktop
All ignitors work, but right front burner will not light.
gud day,remove the burner base & plate to see the injector (gold color) remove it by using soccet wrench diff.size for diif.brand (common is 7mm) remove it carefuly then u see the small hole very small,clan the hole by using niddle or anyting u want to clean,b4 u back the injector, clean the place wer the injector position by using a vaccium.clean it all if u want but carefuly.unplug & turn of the gas. tnx gerbee gomez
Jan 26, 2009 | Jenn-Air JGD8345 Gas Cooktop
The gas is coming through, but does not light.
I have the same grill,and sometimes the same problem.First,with the gas off or completely disconnected,remove the grill grates and the flavor bars from the grill.Now you can see the heating element.A small wire brush will do the trick.Gently clean all the little holes in the element where the gas comes out.Then,with compressed air or even canned air(like what you use to clean a computer with)blow out the holes you just cleaned.Reassemble the grill and light.Should work fine after that.
Dec 28, 2008 | Weber Genesis Silver B Grill
Swooshing sound in oven when burner ignites
the valve your talking about with the two wires on it is the safety valve and should not let gas in without the ignightor being on sounds like its leaking i recommend shutting the gas off till the valve is replaced there is no piolet light on theese ranges
Jan 18, 2008 | GE JGBS23 Gas Kitchen Range
Whirlpool 30" Self-Cleaning Freestanding Gas Range - Black-on-Black Logo
143 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
