Question about Fetco International CBS-31AAP
Fetco CBS-31Aap over brewing
Our Fetco CBS-31Aap brews one pump pop full of coffee, then stops brewing, but then starts brewing again and we end up with coffee all over the counter. What can we do to make sure it brews only one pump pot full of coffee and does not keep going later on?
It's possible that your airpots are too small. We have the same machine and 3.0 litre airpots and it's perfect. But I can't find the right filters for it! I'm currently using a bunn filter and MOST of the time I end up with a lot of grounds in my coffee.
Posted on Nov 01, 2008
The brew group pops off after a cycle. the lever on the bottom gets stuck and doesn't move across to produce the "puck"
a.) Group get of is place when it is not clear and and there is big pressure.
b.) Behind the group there is a switch that stops group motor when group reach the end.When that switch (micro switch) is not working correct the motor doesn't stop at the end and the pressure pulls it out.
Mar 18, 2015 | Saeco Talea Giro Espresso Machine
How do I stop the water in my 2032
The only thing that comes to mind is the brew solenoid on the top of the machine. The gasket might be damaged or something is keeping it open.
May 18, 2014 | Fetco International CBS-2032 Coffee Maker
When I brew on one side of my Fetco cbs-52h, both sides brew. Any idea?
Refilling water in the tank does not stop at the appropriate level. Is much higher than the height of the level sensor which causes the other party also poured water. Descaling of the level probe should solve the problem.
May 04, 2014 | Fetco International Coffee Makers &...
Fetco cbs 51h drips water
Replace the brew solenoid on top of the sprayhead. Either something is keeping the spring and gasket open or the gasket is damaged. Get a rebuild kit from fetco or a new brew solenoid.
Oct 02, 2013 | Fetco International Coffee Makers &...
Water keeps running will not shut off
Where is the water running out of? Does it come from underneath, the top near the spray head, the sprayhead itself or somewhere else?
Sep 10, 2012 | Fetco International CBS-31AAP
Fetco cbs-51h coffee maker not heating hot enough. turned thermostat all wasy up. coffee luke warm.
It can be the Temperature sensing probe, heating element or a loose/burned wire connection.
Adjusting the brew temperature is not going to help
Jan 17, 2011 | Coffee Makers & Espresso Machines
Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Apr 14, 2010 | Saeco Odea Giro Plus Coffee Maker
Not heating
yes just remove the cover lot of time it just thr femelle therminal that overheated cut the old therminal clean contact put a new therminal cheers
Jan 21, 2008 | Fetco International CBS-51H-10 Coffee...
Coffee Makers & Espresso Machines Logo
247 people viewed this question
Top Fetco International Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Fetco International Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
