Question about Pioneer HDJ-1000 Professional Headphones
Left side is quieter than right side and when pushed on makes crackling noises and sound gets louder
Most likely cable is very loosely contacting the jack or earpad. Will need to be taken apart and soldered.
Posted on Nov 15, 2010
Is there a bearing or bushing on the shaft that the left axle slides onto on a 1999 Bonneville se?
i have been fooled by this one way to many times. when a wheel bearing or hub assesembly is making noise, it will sound like it is comming from the other side. i do not know why this is. but one test will prove if and which one. when growling noise occurs, notice, when turning left or right, does noise get louder and quieter as you turn? if so then it is wheel bearing. when turning left the right side will make more noise. when turning right the left side will make more noise. if always the same then, tires or transmission need addressing. the cv axle does not make a growling noise, unless front wheel drive car does not move, it makes a clicking or poping noise. sorry but at least you dont have to replace other axle
Sep 12, 2014 | 1999 Pontiac Bonneville
How do I check for worn wheel bearings
lift vechiel and support by jack stand. grab top and bottom of tire and wiggle it in and out, alternatly. or up and down, depending on how you look at it. but easiest way is to drive it. when noise happens, turn left and right, if noise gets louder or quieter as you turn then its guareenteed to be a wheel bearing. turn left and get louder, replace right side. if turn right and gets louder replace left side. if noise does not change due to turning. then not wheel bearing making noise.
Sep 12, 2014 | 2005 Ford Explorer
Loud humming noise front end moving
While driving, slightly turn the wheel left and right, to see if the noise gets louder and quieter. If it does, you have a wheel bearing that is failing. Then you need to isolate which side is making noise and have it replaced. SOON
Nov 03, 2013 | Mitsubishi Outlander Cars & Trucks
Gear type noise when driving.noise changes with speed of car.stops when car is not moving.2000 pontiac gran prix
Hi, if this noise changes when turning left or right, (gets louder or quieter), there is a good chance a front hub is bad. For instance, if you turn right, and the noise gets louder,the left hub is bad, and vice versa for the other side. You can normally jack it up, spin the wheel and hear the noise, or wiggle the wheel, and see if it has play. Good luck...
Jul 12, 2011 | 2000 Pontiac Grand Prix
Slight noise and vibration when driving straight gets louder when steering to the left
i think so it is the problem of ur battery.check the wire of battery which is connected with horn
ok
Feb 14, 2011 | Ford Focus Cars & Trucks
It starts In 3rd and when in 5th while still accelerating, a noise which sounds like it's coming from drivers front side, the best I can describe it is it sound like a commercial paint shaker shaking a...
Noises from axles can be really deceiving. The sound is transfered throuh the transaxle and can resonate through the entire vehicle. The turning to the left thing makes it sound like a problem in the right wheel/axle area. Wheel bearings and axles tend to make worse noise when they are on the OUTSIDE of the turn. More of the vehicle weight is shifted to the outside due to centrifugal force. Thus, if the noise is louder when turning left, this puts the right axle to the outside of the turn and the most likely to be the source of the noise. (and vise-versa) The fact that the noise calms down while cruising makes me believe that it is not a wheel bearing. Wheel bearings can make more noise in turns, however, they usually make a "roaring" or loud "humming" noise that gets louder with speed. An axle is more likely to change or get louder according to engine load more than rotational speed. (Way worse while accelerating or climbing a hill) I would be taking a hard look at the right axle.
Jan 25, 2011 | 1997 Geo Metro
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
Noise right front wheel sounds like wheel bearing, 1998 Dodge 3500 Van
try steering the the car to the right and the left while driving down the road. listen for the noise to get louder or quieter as you steer the car. which ever direction you steer and it gets louder it will be the bearing on the other side. for example if you turn right and it gets louder its the left bearing because you have just shifted the vechical weight to the left side by turning right. and also in that same situation the bearing would get quieter because you have just unloaded the left bearing and put the weight to the right side.
Mar 16, 2009 | 1998 Dodge Ram 3500 2WD
Alero loud humming/roaring sound coming from front end.
That's indicative of a wheel bearing, which is why you were told to change that out. However, it's also possible that the carrier bearings in the differential (where the drive axles attach) have gone bad. That happened to me on my 300ZX several years ago, and I had to replace the diff bearings. I would have them checked out somewhere other than a dealer (you'll probably get a better price from an independent shop).
As a sidenote, to be sure it wasn't a wheel bearing, if you hear it quiet down in a turn one way but get louder in a turn the opposite way, it's likely the wheel bearing. If you turn left at speed and it gets louder, then it's the right bearing (since you're loading up that side of the car). If it gets quieter in a right turn, it's the right side (you're unloading that side of the car and not putting as much weight on it, so it doesn't drag as badly). See if you get that symptom just to be sure that the wrong side front wheel bearing wasn't changed.
Sep 01, 2008 | 2001 Oldsmobile Alero
Pioneer HDJ-1000 Professional Headphones Logo
511 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
