Question about HP PSC 1510 All-In-One InkJet Printer
I have the HP 1510 series all in one printer and it says check ink cartridge... Black. I just put a new cartridge in and it still says something is wrong!
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
  • 30 Answers
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Posted on Aug 19, 2008
SOURCE: expired HP printer cartridges
Hi everyone HP Cartridge expiration problem solved
Model : HP Business Inkjet 1000 series
Problem : Cartridge Expired
Solution : Normally you can't override cartridge expiration date problem but you can hack and overcome from the problem. As per the documents from the web saying this model can remember up to 3 cartridge of one particular colour. Normally each cartridge will expired within 2 1/2 years.
Mine also expired. To disable the link level feedback to system you have to unplug some cables inside of the printer. So you have to search web for that. I was also refilled the cartridge and reuse it upto 2 1/2 years. After that my 4 ink cartridges were expired and refuse to print even the ink levels were good.
How to overcome this problem. HP the International company's cartridge protection technology having some loop hole in their protection. They want more business than what they are selling. They don't like people refill and use their cartridge. They want to force the user to buy new cartridge get more profit.
Normally the each cartridges portion in the printer recognize and memorize the chip bottom of the each cartridge. For example the black cartridge part the printer recognize the chip fixed bottom inside the black cartridge. It won't check or memorize the other color cartridge chips.
I just removed the chip of the black using a nice blade and swap the chip of the pink (double side glue is used to paste the cartridge chip. You have to very carefully do this. Otherwise chip will damage). Do the same trick to other two cartridge. After you swap note down which cartridges you swaped and keep it in safe place. Later it is useful to swap it again. Better swap (1 and 2) (3 and 4). At least you can swap and use the cartridge for 10 years.
Other model of Business inkjet you have to try it yourself. It may work. Best of luck.
Posted on Aug 24, 2008
  • 15 Answers
SOURCE: Printer will not recognize refilled black HP cartridge (#74)
Try to get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Please post if that worked.
Posted on Jul 13, 2009
  • 1684 Answers
SOURCE: INK SYSTEM FAILURE HP8250 I am using genuine HP
Yes, the problem is either air or dry ink in the ink feed tubes. Go to our web site at: www.ccl-la.com Look on the printer repair page and click the HP link. We have a step by step guide to purging the ink feed tubes that should get you back going again. Use the guide for Non-fax function HP printers. If the ink is dry you may have to repeat the purge several times to get the lines clear enough to print. You will also need to have full ink cartridges when you do the reset. If you have any questions just use the email address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Dec 16, 2009
Testimonial: "Very very helpful - this should fix the problem thank you very much!"
Can't install ink cartridge
Here is a link to an HP Video on how to change the ink cartridge (the 1510 is the same procedure as the 1512).
http://support.hp.com/us-en/product/HP-Deskjet-1510-All-in-One-Printer-series/5157551/model/5385180/videos?cc=us&lang=en
Nov 02, 2015 | HP Office Equipment & Supplies
How do I insert Ink Cartridge into HP Deskjet 1510. Do I need to have 2 cartridges inserted. Only use Black.no other details
Dear
You can follow the link. Yes you do have to install 2 carts. to work the printer. However from printer setting you may disable color print.
Note Ink cart head gets clogged when not used prolonged time.
Thanks. Replacing Cartridge HP Deskjet 1510 All in One Printer
Mar 05, 2015 | HP Deskjet 1510 Allinone Inkjet Printer...
What is the model of inkjet cartridge? Is it 0I-HP C9362(92)? coz i cant install in the ink, thx for reply!
Your printer uses the following ink cartridges:
  • HP 92 Black Ink Cartridge (HP part: C9362WN#140)
  • HP 93 Tricolor Ink Cartridge (HP part: C9361WN#14
  • dentifier"><span class="type">SKU</span> <span class="value">C9361WN#140</span></span>HP 99 Photo Ink Cartridge<span class="identifier"><span class="type">SKU</span> <span class="value">C9369WN</span></span> (HP part: C9369WN)
Jun 13, 2011 | HP PSC 1510 All-In-One InkJet Printer
We purchased a HP Photosmart C4400 series last December 2009. I have just put in a new black ink cartridge and the printer is not printing the black properly, it still very faded. I have put in the correct...
Black printer ink in HP Photosmart may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Oct 04, 2010 | HP Photosmart C4400 series
Hi put new ink cartridges. but light still flashes. never used printer before.
Hello Dear,
Every new ink cartridge comes with a protective tape on the circuit and ink head side.
Just peel off that sticker/tape befor inserting the cartridges to printer.
Thanks
Mar 08, 2010 | HP PSC 1510 All-In-One InkJet Printer
My 1510 is printing all black pages, now I'm out
Have you checked the printing preferences>color tab>greyscale>black print cartridge only option is not on?
Apr 02, 2009 | HP PSC 1510 All-In-One InkJet Printer
Hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
Mar 20, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
