How do i set up my centrios model 4015004 to my sanyo reciever
  • 1 more comment
  • mandy803 Nov 14, 2010
    still not getting signal to spraker blue light is on for a few minitues then goes off
  • mandy803 Nov 15, 2010
    transmitter one speaker is about five feet away the other about a foot away
  • mandy803 Nov 17, 2010
    model number is hw-c500
  • 2,200 Answers
1) You need to connect the wireless transmitter to AC power and the red LED will light to confirm power
2) Connect the Audio cord at the back of the transmitter to the Audio output jack of the Sanyo receiver.
3) Turn on the receiver and the blue signal LED will light on the transmitter to show it is receiving a signal.
4) Insert batteries into each of the speakers or connect them to AC power using the adapters supplied.
5) Press the ON/Off button on the speakers and a blue LED will light up.
6) Press the Autotune button on the speakers and you are done! Adjust volume to preference.
Note: Speakers must be within a 7 meter range of the wireless transmitter to work.
Thanks for using FixYa.
Posted on Nov 14, 2010
  • 1 more comment
  • Radio Code Pro
    Radio Code Pro Nov 14, 2010
    Is this the blue light on the transmitter or on the speakers that goes out after a minute?
    How far away are the speakers from the transmitter?
  • Radio Code Pro
    Radio Code Pro Nov 15, 2010
    If the blue light goes out on the transmitter this means it is not receiving any signal from the receiver through the audio cord.
    You need to be sure that the audio cable is correctly connected to the audio out jack at the back of the receiver and not audio in. If you have a headphone socket on the receiver you may also use this to connect the audio cord to the transmitter. The volume on the receiver should be turned up slightly say quarter way.
    Let me know how you get on and if the problem persists give me the model no. of the receiver and whether you are you using a headphone socket or audio out on the back of the receiver.
  • Radio Code Pro
    Radio Code Pro Nov 17, 2010
    What audio out source are you plugging the audio lead in to at the back of the receiver?
    There is no simple audio out jack on the back of this amplifier as far as I see only component out. This is where the problem lies. As far as I am aware the Centrios transmitter only uses a simple audio jack on the audio lead not component connectors.
    I suggest that if you have a headphone socket on your TV you plug the audio lead into this instead to send the signal to the transmitter and see if the transmitter and speakers work then.
My husband three away my transmitter to my Centrios 900 MHZ DIGITAL HYBRID WIRELESS OUTDOOR SPEAKERS. #4015004
So many of these things are made generic and have limited production run. The OEM is not traceable. I
would recommend getting the whole set.
Jun 05, 2017 | Centrios Audio Players & Recorders
I have a centrios clock that has an alarm, tells the time and temperature. I need the manual for it
So you worked out you need to specify a make :-)
Try these instructions or post to this forum. If you provide a model number for the clock which should be underneath it or at the back, I will try to find the specific model. They seem to make a few models. Post as a comment to this posting rather than starting a new one. Thanks
http://mb.nawcc.org/showthread.php?107852-Centrios-Atomic-Clock-Instructions
Nov 04, 2015 | Centrios Televison & Video
How to set the time on Centrios atomic clock?
I had the same issue. This s a great clock radio, but not very intuitive. I've uploaded a PDF of the manual from my clock radio, I hope it is useful.
Nov 30, 2012 | Centrios Audio Players & Recorders
Centrios wrist BP monitor, model 10A03. When pu...
centrios wrist monitor works to inflate and deflate monitor but displays "1" instead of blood pressure reading
May 21, 2010 | Health & Beauty
CENTRIOS DVD recorder switched to black and white output
Hi
As the black and white pic got a snall cross dot patten all over it. If this so the input on your tv that connects to the dvd player as been set to s-video you can change this with remote on tv . regards windyhouse
Apr 03, 2010 | Centrios EDW8020 DVD Recorder
Centrios DVD Recorder
Setting the clock
1. Press SETUP in no disc mode or full stop mode,MENU screen
appears on the TV screen.
2. Using v select SETUP MENU, then press ENTER or >,
BASIC SETUP is highlighted.
3. Using v to select “Set Clock ”, then press ENTER or >,
“Set Clock Setup ”screen appears.
4. Press</>/^/v repeatedly (or numeric buttons) to set the
date and time.
5. Press > to select “Done”or“Cancel ”, and then press ENTER ,
BASIC SETUP returns.
6. To exit, press SETUP.
7. Press POWER to turn off the unit, the clock appears on
the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
Mar 03, 2008 | Centrios EDW8020 DVD Recorder
Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Nov 08, 2007 | Audio Players & Recorders
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
Electro Med Services...
