Question about Kenmore 24032\24036 Top Load Washer
Stopped operating after filled with water for rinse
    President:
  • 1,654 Answers
Have you tried moving the timer dial to other settings? will it work then? if not I would suspect a bad timer. If you are hearing the motor try and run but nothing else is happining you might want to have the couling to the motor and transmission checked out, these are common problems with these washers. Can you move the drum around freely? If you were hearing a grinding noise before this happened I would suspect the coupling, if not I would start with the timer.
Posted on Nov 14, 2010
3 Suggested Answers
SOURCE: won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Posted on Apr 04, 2009
marka19
  • 1430 Answers
SOURCE: coin operated washer does not fill up in rinse
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Sep 21, 2010
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Washer stop in middle of rinse cycle
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Squire
