Question about GPS
Updates for usb to serial port cable 2608042 - GPS
4 Suggested Answers
RPFinney
  • 385 Answers
SOURCE: garmin 72 to laptop serial to usb
One of These will work for you, no programme needed.
Here
Regards
Posted on Apr 16, 2009
  • 121 Answers
SOURCE: eTrex legend serial to usb cable problem
Have you tried using the cable with another device just to check it's working ok.. And try a different usb port also, they can be funny that way.
A Garmin rep I spoke to about this told me (off the record) to just go to my local electronics store to pick one up for app €15 as the same thing from Garmin would be about €75. So it's basically the same cable and should work. I tried it with a generic cable here in the shop and it worked in one usb port but not in the other two so a bit of trial and error is needed.
All that failing I'd bring it back to the shop and ask them if there is a different type you could try, possibly you need one with a higher data transfer capability.. But try the cheaper and easier options first..
Posted on Oct 07, 2009
  • 65 Answers
SOURCE: need software to connect GP31 via serial to USB cable to W7 PC
Make sure you installed the driver for the serial to USB adaptor cable.
Posted on Jul 15, 2010
How do i get my computer to see my 1350 garmin nuvi?
The problem could be the computer's USB port or the cable. Make sure that you aren't connecting to a USB hub or a dock. Try a different USB A to mini-USB cable (match the number of pins and shape of the mini USB connector). Try installing the Garmin Agent software manually from http://www.garmin.com/agent .
Make sure that the Nuvi 1350 is fully charged. Disconnect the USB cable from the computer and turn off the Nuvi. Then turn it back on. Reconnect the cable to the computer at a different USB port. (If you are using a front port, try one of the back ports. Do not just switch to a top or bottom port since every pair of ports share a controller.) If you are using Windows, check if the Nuvi is listed as a mass storage device (press the Windows key + E or double-left click on the My Computer (Computer) icon). Recent security changes prevent USB devices from triggering the Auto-play feature on Windows. (You can change this from the Control Panel in the Hardware section for AutoPlay.)
Next try using a different computer if you can. If the Garmin Nuvi correctly communicates with the second machine, you may want to check the USB controller. Go to the Device Manager (from the Control Panel under Hardware) and expand the Universal Serial Bus controllers. You can remove the driver or check for updates. (Check for updates manually from the computer manufacturer as well.) Reboot the computer and check if the ports work. Check if other USB devices work on those ports. USB ports can fail. Sometimes, you might notice a device getting hot while connected to a failing port. Other times, the port just isn't getting enough power. Check if the power supply is sufficient for the number of devices both inside (hard drives, video card, etc.) and externally connected to the computer.
I hope this helps.
Oct 17, 2014 | Garmin nuvi 1350 Car GPS Receiver
Hot sinc
Dear NWH1
there is convertor available , which converts USB to serial , your need to connect that cable on USB and attach our serial to usb connector to it,
It will work
Thanks
Gizmo
Dec 24, 2007 | Computers & Internet
How to check fo faulty USB port
W 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Check if USB Ports Are Damaged
USB ports are an important part of your computer's hardware.
Many devices connect to the computer via USB, such as music players, cell phones and digital cameras.
This connection lets you charge your devices and manage files on them.
When you connect a device to a USB port, it is typically recognized automatically.
If not, there may be a problem with the port. USB ports sometimes fail on their own, or they may be damaged by force.
Plug a variety of devices into the USB port you think is damaged.
If none of them work, the port is probably broken.
Connect the same devices to the USB ports on a different computer.
If they work, this is another indication your ports may be damaged.
Run Windows Update on your computer to ensure your devices and computer function together and have the latest drivers.
Click "Start," then type "Update" in the search bar.
Click on "Windows Update," "Check for Updates" and "Install Updates."
Open the Windows Device Manager by clicking "Start," then typing "device manager" into the search bar.
Click the Device Manager link when it appears.
Click on each of your USB ports.
In the Properties window, look for "This device is working properly."
If this is displayed for each USB port, they are not damaged, but there may be a problem with your device instead.
Click "Update Driver" next to each USB port in the Device Manager, and Windows searches for and installs the latest driver.
If one can't be found, go to your computer manufacturer's website, and download the driver there. Try to use the USB port again.
Sometimes, outdated or damaged drivers result in a non-working USB port.
Open your computer case by unscrewing or sliding off the side cover.
Use a can of compressed air to clean out the dust from inside, especially from within the USB ports.
If your USB ports are hooked up to the motherboard, remove the cable, then replace it.
These actions sometimes help to fix non-working ports.
http://askbobrankin.com/usb_ports_not_working.html
Sep 05, 2013 | Dell OptiPlex 780 Desktop Computer 1 x...
Verbatim 53029 500gb not working and beeping when first connected
Step 1:
w7 First, please disconnect all USB devices and then perform the following steps:
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb but its not working ports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Apr 03, 2013 | Verbatim 53029 Store n Go 500GB USB 3.0...
I purchased a serial port that is not compatable with my sewing machine, I also purchased an updated software with Bernina to make my embroidery machine user friendly. however,I am unable to connect
Problem is that the Bernina software you are using expects to talk to a 'COM port and the PC's USB serial interface doesn't automatically default to a COM port. Make sure you have installed the software that was delivered with your USB-to-Serial adapter and look on your PC's 'Device Manager' under 'Ports' - you should see the USB adapter listed and it should be assigned to a COM Port number. You need to check what COM port numbers are accepted by the Bernina embroidery software (sorry, I cant remember and haven't got one here presently) - it should be in the Options menu. You have to ensure that the USB 'virtual COM port' is the same as that which is set in the Bernina software. If the Bernina software doesn't support the COM port allocated to the USB interface, go to 'Properties, Port settings, Advanced, COM port number and set this to the same as the COM port number in the Bernina software - hopefully this should set up the link OK, provided you haven't got a COM port clash - to avoid this, it's usually best to choose a COM port number of 2 or above.
Dec 02, 2011 | Bernina Artista 180
How do I connect a 180e serial cable to my usb computer when Artlink and CPS software specify serial port?
I've not successfully managed this ... trouble-is that although you can get USB-to-serial converters, most computers that only have USB ports do not properly 'recognise' COM ports, which is what your Artlink software expects to talk to. I still use an old PC with a 'proper' 9-pin serial port on the back in order to talk to the old Artista range of machines. One of the drawbacks of a 'throwaway' PC industry that expects the rest of the world to continually update everything in response to new interface standards!
Oct 08, 2011 | Bernina Artista 180
My Bernina Artista 180E no longer works with updated Windows. Is it possible to upgrade so that I can still use my 180E and not have to buy another machine?
Just use the free download software from Bernina called Artlink. I used it along with a USB to Serial converter cable to connect to the machine. Works wonderfully. Allows me to still use my old Artista designer software if I want to on an older machine and then when I want to actually transfer the designs I use the laptop with the USB cable.
Feb 01, 2011 | Bernina Artista 180
Tried using usb to seriel adaptor but unable to read while reading 2way radio software. pretty sure its between the usb/adaptor
make sure that both the cable and the software that you are using are set to same Com ports.
Ex. the cable set to Com4, the software must be set to Com 4
To change the Com ports of the cable you just got to Device Manager under System Properties then on the properties of the serial cable there is an option to change the Com port settings.
To change the Com port setting of the software just simply go to its settings or preferences.
Jun 16, 2009 | Belkin USB/Serial Portable Adapter...
I need to connect a receiver to my computer's serial port, and it doesn't work
which serial port and where > sounds like ya need to do the updates on that computer..... and where or why havent you contacted the makers of that computer to see if they can issue support for that simple task ?
Jul 19, 2008 | Dell Dimension 4600 PC Desktop
Vista software download
http://www.p4c.philips.com/files/s/spc700nc_37/spc700nc_37_dwv_eng.exe
Sergio
Todo: Check USB port
Howto:
061027085005_16154.png Refit the USB cable into the port.
061027085005_16154.png Plug the webcam into another USB port.
061027085005_16154.png Use an external powered USB-Hub. Some USB ports on computers do not have enough power to feed USB devices (this mostly occurs with laptops).
061027085005_16154.png Try to install the webcam on another computer.
Todo: Update your computer
HowTo: Update the USB driver in Windows
USB driver update in
WindowsXP
061027085005_16154.png Click Start -> Control Panel -> System
061027085005_16154.png Click the tab Hardware and then click on Device manager
061027085005_16154.png Click at the bottom of the tree on the + sign before Universal Serial Bus controllers
061027085005_16154.png Select the first entry, right mouse click and click on Update driver...
061027085005_16154.png Follow the steps to update the USB driver
Windows2000
061027085005_16154.png Click Start -> Settings -> Control Panel -> System
061027085005_16154.png At the bottom of the tree click on the + sign before Universal Serial Bus controllers
061027085005_16154.png Click on General USB Hub, right mouse click and click on Properties
061027085005_16154.png Click on the tab Driver and click on the button Update Driver.
Todo: (re)install the latest driver
HowTo:
061027085005_16154.png Deinstall any webcam driver (Philips drivers or webcam drivers from other brands you might have installed in the past)
061027085005_16154.png Cleanup the computer with for instance CCleaner (select Issues (1) and click Scan for Issues(2). Fix issues if necessary)
061027085005_16154.png Download and install the latest driver.
Apr 12, 2008 | Philips SPC700NC Webcam
GPS Logo
182 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
