Question about HP Pavilion dv9000z Notebook
My laptop battery fall inside water and now it not working and not charging any more what will i do?
    Problem Solver:
  • 8 Answers
Get repaired if the insider cells can still held charging.
Or have a new hp dv9000 battery from online laptop battery shop like battery4us.com
Posted on Dec 01, 2010
    Brigadier General:
  • 8,909 Answers
Buy a new one.
Posted on Nov 13, 2010
Replaced battery but will not charge
Did it fall in water, or have anything else happen to it (was it dropped ?) Also, check the metal prongs inside the phone to make sure they are touching the metal strips on the new battery.
Apr 06, 2015 | AT&T ATT TL86109 Cordless Phone
Tablet wont turn on
If it was not damaged by a power surge, fall, or water; look at the power supply to see if you have electricity from the wall to the device. If that is burned out, you cannot charge the internal batteries, or turn on the tablet. If the Power adapter is working, then your tablet circuit board is defective.
Jan 07, 2014 | Computers & Internet
Laptop battery falls out
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Dec 03, 2012 | HP Computers & Internet
Hello,today my E66 fell in water n got really dameged,i tried to fix its working properly but wen i insert charger my phone is not getting charged, its not charging, battery is ok,but i cannot fiqure out...
Hello there, usually when your mobile device falls in water the last thing you want to do is charge it. At least this should be the situation for about a week. This is so because even though the device might come on the insides are not completely dry and electricity mixing with water inside the mobile device is the last thing you want.
Although if after you are satisfied that the inside of the unit is dried you can try charging again and if it does not charge then your charging port is bad and would need to be replaced.
Hope this solution has been helpful?
Jul 20, 2011 | Nokia E66 Smartphone
The laptop with the batterey,and pluged in it works,but the batterey is not charging,and without the batterey just the plug the laptop won't work.
Some laptops, by design, cannot work without the battery. It is possible that yours fall into this category.
As for the problem with the battery not charging while the laptop is plugged, please refer to the following article to diagnose & fix the problem:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Jul 13, 2011 | Computers & Internet
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
I have Hp dv6000 laptop, It was working fie before but now it just doesn't turn on. I can see the power lights on front of laptop, It has the power but it doesn't turn on.
Take the battery out and see if it will boot up. If it does then your battery has gone south and probably needs replacing. Lap Tops have Li-ion battery packs and a safety feature built into the battery pack is if the voltage falls below a safe level for the charging circuit to safely charge the battery without over heating, a chip inside the battery pack sends a signal to the computer,"Do not turn on" This will prevent the battery from causing a fire.
Jan 10, 2011 | HP Pavilion dv6000z Notebook
The laptop doesn't charge and cannot work without the battery. when the battery is inserted, it indicates'plugged in not charging'
Most laptops will work without a battery as the house current is converted to usable voltage for the lap top as well as to charge the battery.
The battery is not charging because the voltage level has fallen below a safe level to recharge. Li-ion batteries have a safety feature built into them. A small chip is wired into the battery to tell the power supplly on the lap top that it is OK to charge the battery. If Li-ion batteries internal charge fall below a certain level, that chip signals the charger not to try to charge the battery as it would demand a higher charge rate and raise the battery temperature and cause a fire, so it in effect says don't do it. If the battery charge falls further, then that chip locks out the battery and shuts down your computer.
One thing you can try, put the battery in your freezer for about an hour, and then put it back in your machine and see if it will come back to life. Do not let the battery freeze, just an hour will do. You may want to try this a couple of times, but your batter is at it's life end.
Jan 04, 2011 | Computers & Internet
The laptop has stopped working, it starts on the button but immediately shuts down. There is no power light shown from the mains when the battery is removed. When fitted the battery will not charge but the...
keithncp, Take battery to local shop to prove battery is good when a "dummy" resistive load is placed across terminals and measured voltage is within specification. If voltage falls off more than 1-2 volts, replace battery. 12fixlouie
Mar 12, 2010 | Acer TravelMate 2702WLMi Notebook
Phone not starting
may be the capcitor inside cell phone is gone it just visit to nearby technician & have check wit it ...
may be the damage has been occurred due to accidents like falling to ground or falling in to water...
if no such accidents have happened means surely the capacitor is gone... just visit technician once...
Feb 06, 2008 | Sony Ericsson K750i Cellular Phone
HP Pavilion dv9000z Notebook Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
