Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a WD52527 The Lamp blew out in it. it was very obvious due to the shatter fillaminte on the bottom. I replaced the lamp with a new. Now when I turn it on it goes thru its warm up cycle I can hear the fan turn on then back off again,the orange lite begins to flash and the TV turns off. What could be my problem? Is my fan motor bad?
    Brigadier General:
  • 8,909 Answers
It sounds like you require a ballast unit as well. When lamps age and fail, if left too long the ballast unit is prone to fail at some point especially when it becomes open circuit or explodes.
Hope this helps.
Posted on Nov 13, 2010
Testimonial: "Thank you so very much for your quick response. IYou are my new hero. No other links could give me an answer in a timely manner or correct diagnoses."
  • urvinnyboomb Nov 13, 2010
    Is the ballast something I am able to swap out my self or is this item a take to repair point to be acomplished? thank you.
  • specialistel Nov 13, 2010
    The ballast unit is a high voltage power supply. If you follow the fat wires from the lamp socket the unit that you get to first is the ballast.
    There, hopefully, will be a part number on it and if you can purchase one, fitting is quite easy. Just use your head and photograph with a camera phone, there will be no problem replacing it because you will see where everything went.
    Hope that helps.
The power button is blinking red what do i do
Probably a bad lamp. Pull your lamp door and check the bulb. Usually obvious if it's bad (ie. shattered, blown tube) replace and enjoy!
Mar 08, 2013 | Sony Grand WEGA KDF-60XBR950 60" Rear...
How to replace the projection bulb?
LAMP DOOR LOCATED IN THE BACK ON THE RIGHT HAND SIDE LOOKING FROM THE BACK. IT IS HELD ON BY 2 SCREWS THE LAMP IS SET BACK IN THE TV ABOUT 5 INCHES FROM THE LAMP DOOR SUGGEST A LONG FLAT HEAD SCREWDRIVER TO LOOSEN THE LAMP. INSERT NEW LAMP AND PUT LAMP DOOR BACK ON. THERE ARE INSTRUCTIONS IN YOUR OWNERS MANUAL.
Dec 16, 2010 | Mitsubishi WD52527 52" Projection HDTV
Bought my hitachi 50vs69a tv 3 years ago. put new bulb in six months ago after original shattered. New bulb is not working now. TV comes on and stays on a few seconds then power, lamp and temp light start...
Take the lamp out and examine it. Are there any blackened markes that look like arcing marks? If there are then the lamp may be faulty and that could be caused by the ballast but in my experience of working with Sany and Philips lamps, the ballast units generally fail without causing lamp problems.
I should go for a new lamp.
Hope that helps.
Nov 04, 2010 | Hitachi 50VS69 50" Projection HDTV
When unit was turned off last night it "popped". Now it does not come on and the power light flashes at a rate of 1 flasher per second.
the lamp blew. take it out and see if there is shattered glass inside. if there is, replace the lamp and blow the dust out of the projector. the dust keeps in the heat that the projector is trying to expel. the lamp probably overheated and shattered. otherwise, it was at the end of it's life (usually 3000 hours).
Jan 04, 2010 | InFocus ScreenPlay 4805 Multimedia...
Tv wont turn on
It does sound like the lamp is your problem. You can remove it and inspect it visually for obvious signs of failure. Usually you will see that the arc tube, the glass tube down the center of the lamp, has shattered. Clean out the broken glass from the lamp compartment carefully before replacing the lamp.
Good luck.
Nov 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Lamp light is red
pull lamp from unit and investigate it for integrity
Jul 07, 2009 | Mitsubishi WD52527 52" Projection HDTV
Lamp light coming on my wd52527 when lamp was just replaced tv saying lamp is about to exceded its life
There is a reset of thew lamp timer which should have been done at time of replacement. It is usually the combination of holding 2 or 3 buttons at the same time. The manufacturer usually has it posted on the web or the instructions with the lamp should have the procedure....
Last resort is call the manufacturer tech line
Apr 18, 2009 | Televison & Video
No picture lamp light on
You can find the lamp acces door on the lower back left side. You will have two philips head screw to remove and you will see the lamp. Remove it and look at it. It will probably be shattered. There is also a filter right beside the access door. Be sure to clean that.
You owners manual can provide you with info to ordered a lamp and have it sent to your home
Nov 23, 2008 | Mitsubishi WD52527 52" Projection HDTV
Green hughs on bottom of screen
i would first replace the lamp, even if the lamp isn't the issue you have a backup.
Jan 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD52527 lamp light
Replace the lamp, model 915P028010.  There is a lamp door on the back left bottom of the set (while looking at it from the back).  Take off the door (two screws) and then take off the two screws holding the lamp in place and pull on the handle.  Replace the lamp the same way.  Then make sure to clean the air filters (below the lamp, two screws; and bottom right).  If the set gets too hot it may destroy the set and/or the lamp.  Also, don't turn the set on and off again within a few moments.  It will destroy the lamp.  Take it from someone who had the same problem, keep the filters clean by cleaning at least once every couple of months....Dave
Sep 20, 2007 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
996 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
