Question about Linksys Wireless-G WRT54G Router
For information on how to change your router's password, click here.
All Linksys routers have built-in web-based setup pages that allow
the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup
page, make sure the router is powered on and the computer is wired to
one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router's Web-Based Setup Page
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
If you forgot the router's IP address you can:
NOTE: This procedure will reset your router to
factory defaults. Any settings on the router will be erased. The
router's IP address will be "192.168.1.1" and the username and password
will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
NOTE: If the user name and password of the router
has been changed, type the router's new user name and password on both
fields instead. In case the router login is forgotten, you will to reset
the router.
will be "admin" after resetting. To reconfigure the router, refer to the
links below:
Posted on Nov 13, 2010
Sep 19, 2013 | Computers & Internet
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory
defaults. Any settings on the router will be erased. The router's IP
address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G Broadband Router
Related Articles:
Setting-Up WEP, WPA or WPA2 Wireless Security on a Router
Checking the Wireless Settings on a Linksys Router
Downloading at Linksys by Cisco Support Site
Nov 11, 2010 | Linksys Wireless-G WRT54G Router
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
Windows XP
Windows 7
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Step 1:
Step 2:
Step 3:
Windows XP
Windows 7
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
Step 1:
Step 2:
Step 3:
Windows XP
Windows 7
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Step 1:
Step 2:
Step 3:
Windows XP
Windows 7
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
Jun 22, 2010 | Linksys Wireless-G WRT54GS Router...
Oct 04, 2009 | Linksys WRT54G2 Wireless Router
Oct 21, 2008 | Linksys Wireless-G WRT54G Router
196 people viewed this question
