Question about Elna 3210 Mechanical Sewing Machine
I have set my stitch selector on my Elna 3210 to zigzag and it will only stitch straight. It used to work but for some reason it will not engage anymore. What can I do to fix this?
  • Elna Master
  • 12,241 Answers
How long since it was last serviced? Sounds like it could use some TLC from your local sewing machine tech.
Posted on Apr 20, 2017
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
  • 1027 Answers
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
SOURCE: Will not zigzag
Have the hook timing checked on your machine.
Posted on Oct 10, 2008
RickE1
  • 202 Answers
SOURCE: Bernina 830
Open the top and look below the selector lever. It fits into a forked part that snaps back and forth. This gets gummed up and you need to oil it well and move it back and forth until it is freed up. Then your back in business.
Posted on Oct 18, 2008
My sewing machine only sews zigzag stitches never a straight stitch. Why?
We need to know the make & model machine.
If it is an older mechanical Kenmore, more than likely it is seizing due to old oil turning to glue inside the machine. Unfortunately, these old machines were made too well as the manufacturers never anticipated the machines would be around for 50 years. However, as mechanical machines they do need regular cleaning and oiling with a good quality oil, ie liquid Tri-Flow Synthetic Lube or "good quality" sewing machine oil.
Either the stitch width regulator is broken or stuck or the mechanism that drives the needle bar is stuck. With plenty of time, patience, elbow-grease & Tri-Flow, your sewing machine will probably be sewing like new.
I've used the following method to free up some great old mechanical machines and they operate like new again:
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
Also, be sure to change the needle frequently, ie every 8-16 hours of use. Most sewing issues can be resolved with a new needle.
May 05, 2017 | Sewing Machines
CAn a brother lock 9290 sewing machine do just a straight stitch?
YES. ALL SEWING MACHINES DO STRAIGHT STITCH. EVEN IF YOU WOULD SET THE STITCH SELECTOR TO A ZIGZAG YOU COULD STILL SEW STRAIGHT STITCH BY SETTING THE WIDTH TO ZERO. OTHERWISE YOU COULD JUST USE THE STRAIGHT STITCH CHOICE.
Mar 22, 2015 | Brother Sewing Machines
Elna 3210 raw-edge zig-zag stitch bunching
Zigzagging on the raw edge of a lightweight fabric will pull up, because the needle is swinging to the right side off the fabric, bet solution is to use the three step zigzag to overcast the raw edge, it looks like a zigzag mad of dots in the stitch icon. Dont know your model well, but its late model so should have this stitch.
Sep 26, 2014 | Elna 3210 Mechanical Sewing Machine
Stitch width knob
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Feb 11, 2014 | Elna Sewing Machines
Straight stitch
Tension knob on any machine will be in the thread path and usually above the needle somewhere, while the stitch width and length knobs are usually on the right side of the machine. I cant identify your model but on any machine straight stitch is usually a length of 2.5 and width of 0, while a zigzag the width will be set somewhere between 2-4 depending on how wide you need it to be. There is usually a stitch selector of some sort too but many machines, providing the width is set to 0, you will get a straight stitch.
May 29, 2013 | Husqvarna Sewing Machines
How do I turn the selection dial to zigzag on my Elna Super
I've got a Supermatic manual but I think maybe you mean the earlier model perhaps. On the supermatic you set the stitch width to 2 and stitch lenth to 2+ for a zig zag. In this image, the stitch width selector is marked "3" and the stitch length selector is marked "4".
I've got a feeling that on the earlier model you may need to use a zig zag (single) disc in the Elnagraph to get the needle swing function.
As you probably don't have a manual, you may want to join the Yahoo group called Elna Heirlooms as the members there share info on these vintage machines, and some manuals are there.
Go to www.yahoo.com, sign up, then go to "Groups" and search for "elna Heirlooms". You will need to ask the moderator to join the group but once accepted, you'll find lots of helpful information, check out "Files" for shared documents.
Hope this is of help to you.
Nov 06, 2011 | Elna 2007 Mechanical Sewing Machine
My Elna SU will only do straight stitching it will not zig zag
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 02, 2011 | Elna Quilter's Dream 6003Q
I don't have a manual for a Husqvarna 6440 and don't know how to switch from zigzag to straight stitch. Everything else seems to be sewing beautifully and it was on straight stitch when I first tried it. I...
You have 3 knobs/dials on the machine, the top left dials the stitch, the top right sets the length and the bottom right set your width. set it 0 for straight.
Mar 03, 2010 | Sewing Machines
Zig zag won't work
Make sure stitch width slider is not set to zero. If not then you either have a bind in the needle bar pivot or an electrical problem (bad stepper motor or bad circuit board).
I can't remember if this machine has a twin needle lock out, if so turn it off.
Good Luck!
Jan 28, 2009 | Elna 2007 Mechanical Sewing Machine
Elna 3210 Mechanical Sewing Machine Logo
106 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
