Question about Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel
All controls blank, like a fuse is blown for the control panel, what's likely problem, and how to solve
  • 134 Answers
You may be right sounds like a blown fuse you just need to take the cover off and check the fuses that is a good starting point also make sure you are getting power to it from the receptical you never know could have a tripped breaker or a faulty receptical.
Posted on Nov 13, 2010
No temperature display cant set temperature
Located behind the access panel there is a grey box that is the spa pack. Open that up with the 2 screws on the top of the pack. There is a small glass fuse on the circuit board. One of those fuses is most likely blown. If that is not the culprit you need a new topside control. More than likely it's the fuse.
Mar 04, 2013 | Jacuzzi Balboa R574 System for 1 2 Speed...
I have fisher and Paykel dish draw (single) and can not get the power turned on
If the display is blank then that does not necessarily mean there is no power.Please check the panel located at top inside the door. If that too is blank then the controller could be faulty or the power coming to the controller could have cut off. One reason might be the heater fuse is blown. This is located within the heater element and the whole heater assembly needs to be replaced. Alternatively, the power filter is blown. This is located at the base of the dish drawer assembly under the drawer. If you are not familiar with repairing dishwashers, you will need to call the technician.
Nov 05, 2012 | Fisher and Paykel Dishwashers
1996 previa wher is fuse box
on the previa, the main fuse box is located in the top of the dash board, the panel above the heater switches comes off to reveal it. There is a little level/clip just above the heater switches hidden by the curve of the panel, push and lift. Turn the ignition switch to the "Off" position. Insure the component with the suspected blown fuse is turned off. Reach under the central instrument panel cover, located above the air conditioning controls in the center of the dashboard, and press upward on the panel cover release latch. This is where most of the fuses are located in a Toyota Previa. Lift the panel cover up and off. Observe the underside of the control panel cover. It will have a schematic diagram along with the name of each circuit controlled by the corresponding fuse. Determine the location of the fuse that controls the affected component. The Toyota Previa makes use of three different types of fuses: type A, which are thin and elongated, type B fuses that resemble a box with a window in the top to reveal the fuse link, and type C, which also resemble a box with a clear plastic top. Grasp the suspected fuse and pull straight up and out. Look down through the clear top of the fuse. If the metal connector is broken and not connected, the fuse is blown. Insert a replacement fuse of the same type and amperage rating into the vacant slot. Replace the instrument control panel and press down until it snaps closed. Turn the ignition switch to the "On" position. Activate the suspected component. If replacing the fuse did not solve the problem, troubleshoot further or take the car to a qualified technician for repairs.
Read more: How to Replace Fuses on a Toyota Previa ' eHow.com http://www.ehow.com/how_4558504_replace-fuses-toyota-previa.html#ixzz1LmKZ6Zqn
May 08, 2011 | 1996 Toyota Previa
The microwave control panel suddenly went blank. I checked the power at the outlet and it is fine. There wer eno fault codes or anything else - my guess is that the control panel failed
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. you can also take a bit from a screw driver or drill and place it in the fuse holder. then plug the microwave back in, and it should come on.
Feb 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KCMS1555RSS - display completely blank and does not function. Is it worth fixing?
i would try and see if the fuse is blown in unit ... normally behind control panel there is a in line 20 amp fuse that may have blown.... if the unit makes noises when you touch the buttons but no display then you have a bad control board assembly
Jan 11, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
Unit will not turn on. Display is blank.
Power supply is the problem. If not under warrenty, open the cover and look for blown capacitors. If there are, try replacing those or have them replaced. Might solve your problem
Feb 03, 2010 | Pioneer DVR-225 DVD Recorder
Digital clock visible image no longer shows, just blank!
look on the fuse panel on fuse panel cover inside ther is a list and diagram of fuses. Check corresponding fuse if it is not blown then you need to replace a bulb.
Nov 13, 2008 | 2003 Toyota Corolla
No display .....
Problem :
The control panel will go blank
Solution :
There are many items which can cause the machine to have a blank control panel or no display. There could be a problem with the memory, a blown fuse on the fuse pcb, a defective control panel, boot rom, memory, etc...
One other cause of the problem which was confirmed to cause a blank display condition is the main controller fan. When the main controller fan was unplugged the display would come up and the machine would then give an E code.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Jun 27, 2008 | Canon Office Equipment & Supplies
Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel Logo
144 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
