Question about HP Pavilion a1213w (ED898AA) PC Desktop
I took out one of my two .5 gig ram "cards" and
    President:
  • 2,653 Answers
The sizes don't have to match but if the speed of one module is slower and the other is faster, the faster one will slow down to match.
If I were you I would check to see if I had the latest bios revision.
Posted on Nov 13, 2010
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
No output
Make sure you have your speakers connected to the main output. Also, in the "Universal Control" "Mixer" window, make sure that at least one of the mixes are assigner to "Mo", which stands for main output.
Feb 03, 2010 | PreSonus FIRESTUDIO Sound Card
RAM Upgrade
How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251
Not only is there a maximum amount of memory that your computer motherboard can accept, there is also a maximum amount of memory that your operating system (OS) can accept. For instance, when you install 4GB of memory in a 32-bit Windows system (the most common version; 64-bit systems are typically used by high-end users), your system reports only 3GB or 3.5GB.
First , we can assure you, there isn't a problem with the memory. While Windows allows for 4GB of memory to be addressed, it does not equate to 4GB of physical memory. Some of the memory (regardless of how much you have installed) is reserved for use by the devices that you are using, such as a graphics card, PCI card, integrated network connections, etc, meaning it is unavailable for use as normal main memory. Upon startup, your system calculates the amount of memory needed for these devices; if you haven't maxxed out the memory in your system, it's invisible to you, and all your physical memory (the installed RAM) is available for use. However if you've maxxed out the DRAM in your system, this amount will be deducted from your physical memory, so you can't use 100% of your DRAM. The maximum memory limitation varies by operating system, For instance, the 4GB memory limitation doesn't exist in 64-bit versions of Windows.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | IBM PC 350 PC Desktop
Ati radeon hd3800 conflicts with ram
just a shot in the dark here maybe you're power supply needs a little more power to support that video card + 8 gigs of ram + all other peripherals you use
Feb 24, 2009 | Intel DX48BT2 Motherboard - X48, Socket...
SD card slot nothing happens
Sounds like it is defective I just came across 2 bad scandisk cards both 2 gig.
Jan 26, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Put new vid card in pc it will boot but no pic put another vid card in it boots just fine
What kind of fan do you have installed? Cpu wise? it sounds like your cpu is overheating when your playing games. Due to high graphics. Try getting a better cooling system to stop the shutdowns.
With the ram, is it because your Gpu shares some of the ram?
This is common with chipsets and some GPUs.
Sorry or posting twice, im having some issues of my own here ;)
Sep 08, 2008 | ASUS P5N-E SLI Motherboard
Ram problem
Kamel,
First of all you should know howmuch maxim RAM your board will support and which type of DIMM's it accepts. You can see on your motherboard manufacturer's site.
  1. Try each on in all slots one by one to verify all slots are well. if not try to clean and check again.
  2. If its ok then put both together and check out, if not then try to change the place and clean the contact point as well.
Thanks
Iqbal
Apr 09, 2008 | Computers & Internet
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Ram upgrade
In order to see how many MHz is your desktop, please right click on your "My computer" icon and select "Properties" from the menu.
It will open the system properties window. select the tab "general" and you will see how many MHz is your desktop.
If you have found this solution helpful please rate it as "solved", otherwise please ask here again.
Thank you :)
Oct 12, 2007 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
