Question about Lexmark X5470 All-In-One InkJet Printer
Cartridge hold will not move to center - Lexmark X5470 All-In-One InkJet Printer
Ink cartridge in Z705 will not move to center of carriage for changing when top is lifted Even though the Belt is moving. Help !!!!!!!!!!!.. >:( :( :'(
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
I hope this helps.
Oct 24, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Why will my ink cartridge not move to the center so i can tak e it out.
Sep 10, 2011 | Lexmark X2470 All-In-One InkJet Printer
When i power up cartridge s do not center
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to the power source.
Apr 15, 2011 | Lexmark JetPrinter Z55 InkJet
I removed The deskjet ink cartridges(56/57) in my HP5650 to replace them with new ones. However, I am unable to install the new ones as the two bottom trays to hold them will not move. Can you help Joe...
Usually when you open the cover the cartridge holder should move to the center that will allow you to install the cartridge. If this is not the case you could force it to move by:
  1. Opening the cover as if you're installing a new cartridge.
  2. Unplug the power cord
  3. Lift the cartridge holder enough height to allow you to slide it on to the center
  4. After sliding, you should be able to install the new cartridge.
  5. After the installation close the cover and power up your printer.
Feb 24, 2011 | HP DeskJet 5650 InkJet Printer
The ink cartridges are jamming and wont move please could u help
Feb 18, 2011 | Lexmark Z615 InkJet Printer
How do I change the cartridge
  • Turn on your printer and lift the access door. The print carriage will move to the center.
  • Once the print carriage has stopped moving, remove the empty cartridge by pushing down on it and pulling it towards you.
  • Remove the replacement cartridge from its packaging. Peel the pink tape away from the bottom while holding the cartridge by the sides.
  • Hold the replacement cartridge with the label on the top. Slide cartridge into the appropriate slot. Insert cartridge at a slight angle, then apply pressure until it snaps into place.
    • Close the print carriage access door.
    • Align the printer if it prompts you and if not just align it manually
    Jan 03, 2011 | HP 5510 4-in-one Printer
    How do i remove the ink cartridge from my hp psc 1410 printer
    It is very simple to remove the cartridges out from the printer if the printer is not in a error state.
    Printer should be Powered on.
    Open the front access door ( not the scanner lid )
    The carriage which holds the cartridges should automatically move to center.
    To remove the cartridge, Press the cartridge down ( with thumb ) and pull it out.
    Do the same for other cartridge too.
    If for any reasons you are not able to see the carriage in center position, try to move it manually in center to remove the cartridges.
    IF none of the above steps help you remove the cartridges or the carriage is stalled on right side or left side, there are likely chances the printer is Defective.
    Thank you for contacting FixYa.
    *Please rate this solution with thumbs up
    Nov 20, 2010 | HP PSC 1410 All-In-One InkJet Printer
    How do u change ink cart
    The process of changing ink cartridges varies slightly by the make and model of your printer. Open the cover to the area where your cartridges are installed while your printer is turned on. If opening the cover automatically prompts the inks cartridges to move and center in a position where they are accessible, then all you have to do is remove and reinstall new ones. If the cartridges do not automatically move and center themselves where they can be changed, then your printer requires an additional command that you do manually to make this happen. Some printers require the user to push the power button down and hold it for 10 seconds to have the machine move and center the cartridges in a position that can be reached easily by your fingers. Some even have an extra button to push that has a little picture of an ink drop next to it which brings the cartridges forward for replacement. If you cannot reach the cartridges easily, or opening the cover does not automatically move and center them then check your manual for the procedure or repost your question inlcuding the make and model number so that we can locate this information for you.
    Lets move forward.
    Once the cartridges are in an area that is easily reachable, the next step is to eject the cartridge which needs to be changed. This procedure can also vary by make and model. Look at your cartridges and check for a plastic ejection lever in front that can be pushed down by a finger tip. If you see one, push downward and see if the cartridges is ejected outward towards you. If it is ejected, then replace with new cartridge and push downward to lock it into place and your done. If there is no plastic ejection lever in front of the carriage which holds your cartridges, then place one finger on top of the cartridge you wish to remove and push downward slightly and pull it towards you until it unlocks and releases it. Then remove and replace and push down and forward to lock the new one by into place and your done.
    I can give you specific instructions pertaining to your make and model printer if you supply this information on the website. Good luck!
    Oct 26, 2010 | Office Equipment & Supplies
    How does one change an ink cartridge? On my computer the cartridge container doesn't come to and stay at center position?
    You didn't specify which type of printer you have. Is there another door that opens and gives access to the cartridges? If not, let us know what kind of printer you have. Good luck!
    Mar 12, 2010 | Office Equipment & Supplies
    Cartridge gets stuck....
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I had the same problem it seems this printer (i don't know a lot about printers) has a lever that holds the cartridge bay at the right for cartridge cleaning. If you move the printer on the side or during a paper jam it can move this lever and get out of sync with the cartridge bay cleaning process witch is when you power on the printer and this problem may happen.
    I took the top off the printer and noticed that when the cartridge bay wanted to move to the left this lever wont go down holding it at the right and when it did go to the left it was with some force so the cartridge bay was always out of center (it supposed to be at the center when you turn on the printer otherwise it will give an error message) so I pushed manually this lever at the right (is hard to move but you can move it) and let the cartridge bay sit on the cleaning pads at the right then turn off the printer.
    When I turned on the printer, the cartridge bay returned to his proper routine and was centered so the problem was solved. I hope it helps.
    Jul 24, 2008 | HP PSC 1315 All-In-One InkJet Printer
    Lexmark X5470 All-In-One InkJet Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
