Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
The partition between the refrigerator and feezer is hot at the gasket sealing area. The gasket sealing area at the top is also hot. The temoerature is hot enough that you can hold your hand on it for 5 seconds before youhave to remove your hand.
  • dickweber2 Nov 14, 2010
    The coil was dirty but cleaning it diod not solve the problem.
    The information is interesting but problem is not solved.
  • Kenmore Master
  • 43,501 Answers
Many refrigerators run the hot gas from the compressor through there to keep condenation from building up....
A condeser that is plugged with dust and dirt cause it to be very hot....
Other units use a heat strip... If you have an "energy saver" button make sure you have it on which will turn the heat strip off...
Sometimes the heat strip will go bad... it should be self regulating..
heatman101
Posted on Nov 14, 2010
Replaced freezer gaskets now not sealing well
Jay, Check to see if hinge can be adjusted so door closes tighter, may be a faulty door seal, or maybe it needs manipulated to soften, shape, stretch it to seal better. You can try the dollar bill trick between the seal and fridge to locate the problem/leaking spots. The bill should not pull out with out there being a little force, no force means seal is not proper in that area. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Check The Seal On Your Fridge And Oven
How To Test And Replace Bad Refrigerator Gasket
How to Fix Gaps in Refrigerator Door Gasket
How to Check Freezer Door Seal DoItYourself com
Aug 20, 2016 | Refrigerators
How do I determine the reason for excessive frost in freezer?
the seals are leaking ,letting humid air in,creating frost,get a new gasket,you will also save alot of electricity
May 20, 2015 | Whirlpool Refrigerators
My refrigerator is 15 years old. it has a top freezer. has been a good refrigerator until a few weeks ago. the motor is a lot noisier and the area around the freezer door ( top and sides) is really...
The compressor may be short cycling due to a condenser fan stopping while the compressor is running. The heat you feel is coming from the hot gas cycling through what is called a yoder loop. The yoder loop is there to prevent moisture buildup around the door seal. When this area becomes hot it means that something is wrong with the cooling fan below the refrigerator and cleaning the area may help. Please be aware that the fan may appear to be running normally but keep an eye out after cleaning because a bad fan does not always stop all the way and I have made up to three trips before catching one that has stopped. Always unplug the power before attempting to reach inside the compressor area. Feel compressor top to see if warm, hot or too hot to keep hand on top. Again this problem can be the condenser fan, dirty condenser restricting air flow or the start components of the compressor are worn out or all of the above. Fixing this now may extend your refrigerators life another 10 years. If you have any questions I will be here to assist you, Thanks, Sea Breeze
Jun 13, 2011 | Magic Chef Refrigerators
Refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
Apr 25, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I am experiencing frost build up on the top part of the door as well as the top part of the inside of the freezer. all other areas are fine
You have an air leak. Usually right where you frost build up is, however since hot air rises, sometimes this leak can be anywhere. Make sure your door closes tightly and your gaskets are clean and making good contact. You may have to adjust the gasket, adjust the door, or replace the door gasket. If there is ice on the floor of the freezer, you have a plugged drain line. In very rare instances we have found, where the freon lines enter the freezer, in the back or under the freezer, missing or fallen refrigeration putty that seals around the lines. Good Luck, Appliance Specialists
Jan 28, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Center front partition is very hot!
Either your coils are dirty ( clean from the front after removing the kickplate , only what you can get to ) or , the condensor fan motor is bad ( motor which cools the compressor ) .
Jul 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Center partition wall of refrigerator is hot !
Sounds like your condenser fan isn't working...Take the back cover off to see if there's anything stuck in the fan blades. Usually when the fan stops, the compressor & tubing that runs between the doors get really hot. You may also want to clean your condenser coils.
Feb 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
The feezer door seal needs replacing on my fridge feezer model ZFC 56/38FCC
most door seals nowadays are foamed in and you can only replace the whole door
Sep 04, 2008 | Zanussi Refrigerators
Refrigerator door gasket
This area is hot as it is a mullion heater to stop condensation from occurring during humid days. New units use the high pressure line from the sealed system to do this. Your unit may have poor circulation causing the compressor to work harder as a result. Clean your condensor coils and make sure you have a bit of space so the air can circulate around the unit.
Sgt 48
Jun 11, 2008 | Frigidaire Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
242 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
