Question about Frigidaire ATF6000ES Front Load Washer
A brand new front load washer, completely level both side to side and front to back. Goes crazy in the spin cycle. Not sure what else to do?
    President:
  • 1,082 Answers
It's" ..brand new" Warranty call !!
Posted on Nov 13, 2010
Wash shakes on the spend cycle
I would check to make sure the washer is level, the drum sounds like it's not spinning evenly and if the load isn't unbalanced it might just not be level front to back and side to side.
Mar 01, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
Tub shakes like crazy , have to stop machine , please help
Firs thing to check is that the machine is level from front to back and from side to side. This can be adjusted with the screw adjustable feet on the bottom. Next is to not over load the machine and make sure the load you have in there is evenly balanced/distributed when it starts into the spin cycle.
Jun 01, 2014 | Whirlpool GHW9400 Front Load Washer
Since I have owned my washer I have at least one load that does not spin completely dry enough.
An occasional load that does not spin dry enough is nothing to be overly concerned about. The usual cause of this problem is due to a load that the washer was unable to balance and therefore it never entered the high speed spin cycle. There are a couple of things you can do to minimize this problem. If you are washing an item of clothing that is made of heavyweight fabric make sure you wash at least two of the same item or throw several towels in to act as a counterbalance. Also, make sure your washer is properly leveled by using a four foot level and checking from front to back and side to side. Using a level that is shorter than the length or width of the washer may not produce a true level.
Mar 05, 2010 | GE WBVH6240F Front Load Washer
Front Load Frigidare washer bouncing on spin, very bad!!!
Hi, not sure if you have solve this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
Jun 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Hi, not sure if you have resolved this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
During the final spin cycle, our front loading whirlpool is making a really loud noise - it sounds like a train is going through the house. It is in the basement on a concrete floor.
If the washer is brand new, look on the back panel and make sure the 4 transportation bolts have been removed. The bolts should be roemoved completely - they are only necessary to protect the washer during transportation.
If the bolts are removed, adjust the front two legs to be 1/4 inch higher than the back two. That 1/4 inch will balance the washer during the spin cycle, perfectly.
Apr 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Off balance
make sure you have all the shipping material out of unit..4 bolts in back and styrofoam under tub if so ,then get a adjustable wrench ,,,put unit in drain spin cycle or spin cycle only..when unit gets to fastest spin ,,thats will come when its about 8 minutes left..tighten each leg lock nut on unit until unit stops vibrating..only turn the lock nut not the leg..only adjust lock nut on legs in high speed spin
Dec 25, 2008 | GE Energy Star WCVH6260F Front Load Washer
Front load washer- spin cycle is like a hurricane
be sure all the shipping materials have been removed ..next adj all feet up as close to bottom of washer as possible ..try rocking machine ..if movement detected adj only foot necessry to firm up washer ..still have vibration suspect floor ..front washers need a good SOLID floor
Aug 16, 2008 | Washing Machines
Washer was jumping and dancing when it got to spin cycle
The only thing to check is to see that some struts behind is taken off. This is inserted to prevent the drum from banging around during transit; refer to your manual. Important.
Jan 12, 2008 | LG WM2487H Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
47 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
