Question about Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore elite heavy duty king size quiet pak II Top Load washer stopped in the middle of the wash cycle and began to give off a burning rubber smell( I think it overheated). I turned it off and removed plug. It would not start again or drain after letting it cool over night. Sounds like I had over loaded it and the coupler is broken. What I don't understand is why I can't get it to empty (drain)on the spin cycle. Is that normal or is there a possibility the pump is bad as well.
  • 60 Answers
SOURCE: Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Posted on Sep 14, 2007
tzweeb
  • 318 Answers
SOURCE: kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Posted on Jan 31, 2009
SOURCE: 22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
Posted on Jun 19, 2010
tiger56h
  • 176 Answers
SOURCE: Kenmore 90 series Heavy Duty Super Capacity Plus
hi check the lid swetch
Posted on Sep 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite, SM 7711174, Heavy Duty, King size,
It appears your tub seal has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
Motor on kenmore elite washer quiet pak ii heavy duty capacity king size wont engage, just hums. and ideas?
Sounds like you motor coupling is gone this happens when over fill washer or place carpets/ bed blankets
Feb 15, 2015 | Kenmore Washing Machines
No heat
I can be several things, but most common is a burned out heating element. This can be tested with an Ohm meter.
Mar 15, 2014 | Kenmore Dryers
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
My Kenmore elite heavy duty king size quiet pak II Top Load washer stopped in the middle of the wash cycle and began to give off a burning rubber smell( I think it overheated). I turned it off and removed...
The pump is connected to the same drive that drives the tub, if the coupling is bad then the pump won't work. Does the motor start and try to run? Do you hear a grinding sound when you start the motor? If so then I would suspect the coupling is bad. this is not an expensive repair, should be right arond $100.00 to replace the coupling and you migt want to get the agitator tabs replaced as well since they wear out about the same time as the coupling. This will only add about $10.00 to the repair. The drum has to spin to pump the water out!
Nov 13, 2010 | Washing Machines
May 17, 2010 | Kenmore 22942 Top Load Washer
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
May 16, 2017 | Kenmore 22642 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
137 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
