Question about Relic Two Tone Day Date Dress Watch for Men
I just purchased this watch and the store provided no setting instructions. where can i get them? (zr15490)
I need to know about the warranty for my Diadora watch I want to contact The company
It depends on where you purchased it from. http://www.jomashop.com/diadora-watch-6126m-03m.html
You should be able to contact the store you purchased it from for further instruction
Jun 23, 2015 | Watches
I just purchased a Diesal Watch DZ7211 and the manual that came with the watch does not have the DZ7211 in it a all. So I went back to the store that I purchased it from (Graffitti's in Key West, FL) and...
Go to http://store.dieseltimeframes.com/webapp/wcs/stores/servlet/ContentView?storeId=33053&page=instructions&catalogId=21503&langId=-1 (click on this link or copy an apste it into your search engine) and you will see a page of diagrams and watch models to which the instructions apply.
Your watch is G1 and G3, so you should scroll down the page (quite a long way) until you find the instructions for your watch. This seems to be a comprehensive guide.
(Their main web site is quite useless as I'm sure you have already found but I managed to find another way to find their instruction list. It is strange that this is not linked to their main web site!
May 05, 2011 | Diesel Watches
We bought the Fossil Brown rectangle watch model FS4284, it stopped working so thought it was the battery. we replaced the battery and then 2 months later it's not working again, faulty battery or is...
  • Change the battery. If your watch stops ticking, chances are the watch is not broken and the battery simply needs to be replaced. You can purchase a watch battery at your local department store or drugstore. Use the screwdriver to pry the back off the watch and place the new battery in the same place where the old one fit.
  • Step 2 If your watch is still not working, determine the problem. If you can hear the watch ticking but the hands are not moving, there may be a gear stuck inside. If only one of the hands does not move, the hand itself could be broken. Once you determine the problem, you can see whether it makes more sense to purchase a new watch or get the old one fixed.
  • Step 3 Check your watch warranty. If your Fossil watch came with a warranty that is not yet expired, Fossil will fix your watch if you send it to the company and pay for shipping and handling. See the "Resources" section below to fill out the Watch Repair Form provided by Fossil.com. If your watch strap is broken, however, Fossil will charge you a fee as broken straps are not covered in the warranty.
  • Step 4 Check a competing local watch repair store. There are watch repair stores located all over the United States that will repair a Fossil watch if your watch is no longer under warranty or if you do not want to pay the shipping and handling to send the watch to Fossil's watch repair department. Although the watch repair store may not have the exact strap you are looking for, it may offer a replacement strap that is similar to the one that originally came with your watch.
  • Step 5 Return the watch to the store where you bought it. If you purchased a Fossil watch that was broken when you purchased it or broke recently after you brought it home, you may be able to return the watch for a refund or store credit. Check with the store's policy before purchasing the watch if you are concerned about returns.
  • Aug 10, 2010 | Fossil Brown Ip Brown Rectangle Ip FS4284...
    Setting alarm in F5015D F1 series watch
    ypu can get a set of instructions by going to their web site (www.jacqueslemans.com).
    On the left yu will see a menu, click on "instructions/catalogues" and you can download the instructions for your watch.
    Feb 02, 2010 | Jacques Lemans F1 Analog Digital Watch
    HOW DO I SET MY CITIZENS ECO DRIVE WATCH I PURCHASED A LIMITED EDITION CITIZENS ECO DRIVE WATCH 0240-2500
    You can get a set of instructions from their web site "citizen.com", select "technical support" and the "setting instructions" and then enter the details off the back of your watch.
    You will then be able to download instructions.
    Jan 30, 2010 | Watches
    Can you change UTC time to current time xone
    If the store you purchased the watch at has not set the time to the correct time zone then obviously the different time zone (UTC in this case) that is showing on your digi face isnt exactly helpful....
    Best bet is to go to the interactive watch instructions on www.citizenwatch.com to follow along on how to get it into your own time zone.
    Just type in your model number exactly JR3060-59F into the search field. On the right side of the page is the Get Technical Info link..click on this choice. Now on this page is the next link...right side at the bottom of the list> Interactive setting instructions. The page changes again and you see the choice menu. Find Zone Settings...click and follow the instructions (note there is sound to it so turn your speakers on if you have them)
    Mar 14, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
    I don't know how to set my timex 1440 sports watch
    1. it is easy all you have to do is hit mode
    2.then you will se all zeros
    3.hit mode again
    4.then you will see a number blinking then press start/stop button and it will change to the next number
    5.then just set it to your clock time and your done!!!!!!
    hope this will help you
    Dec 26, 2008 | Timex 1440 Nylon watch
    Watch
    i bought a world time 50m wr watch or my boyfriend from bidup tv but no operating instructions arrived. How do i reset the digital time and date.
    Aug 31, 2008 | Bulova Watch
    Instruction manual required for diesel watch DZ 7033
    i have found the solution by visiting this site
    http://store.dieseltimeframes.com/text/content/diesel/DieselENGLISH.pdf
    All diesel watches manual instructions or (guide)
    jamil soomro
    toronto
    Mar 02, 2008 | Diesel Audio Diesel Watch
    Relic Two Tone Day  Date Dress Watch for Men Logo
    197 people viewed this question
    Top Relic Watches Experts
    Ansel Alberto
    Ansel Alberto
    deton8 von Splosion
    Are you a Relic Watch Expert? Answer questions, earn points and help others
