I have a D845PT motherboard and i need instructions for the control panel, specifically on what color wires go where and for what purpose
    President:
  • 2,653 Answers
Here's the complete manual.
Hope this helps!
Posted on Nov 13, 2010
I want to know what color wires serve what Purpose in my 1993 kia spectra
they dont necessarily serve any singular purpose each manufacturer will have its own color codes that can even vary by the subcontractor they hired to make the part, usually all the connectors are the same though, if you want to know about the stereo wiring, Crutchfield has excellent bluprints of the wires going to the stereo, navigation, and antitheft wiring and how to bluprints of how to remove door panels and dashboard assemblies, the other wires to engine controls and other equipment will be available at your dealership, but there definatly is no longer any color code standardized in the industry, a green wire could be hot but a red wire is seldom neutral
Jan 02, 2015 | Cars & Trucks
How to reconnect front panel wires to Intel D845PT. Thought I had another identical computer, but its board was a D845GERG2 and is different. I took everything out of the chassis to clean and make sure...
aticus,
Intel Support > Intel D845PT Technical Product Specification,
http://www.intel.com/support/motherboards/desktop/d845pt/sb/cs-013219.htm
Under the heading - Technical Product Specification, left-click on the blue -
A7585201.PDF
The computer you are using now has Adobe Reader on it. Adobe Reader uses PDF files.
I would recommend however, updating to Adobe Reader X (10), though, if the computer doesn't have this version.
After you click on the above file name it may take up to 30 seconds, (Or more), for the first page to come up.
It may also take additional time for the file to fully download.
Using the Down Arrow at the top, and the page number box to the right of it, go to Page 71.
{Or alternatively left-click in the page number box, to the right of the Down Arrow at the top of the PDF file.
The number in the page number box will be highlighted in blue.
Type 71
Now press the Enter key }
D points to the Front Panel header.
The Front Panel header is a rectangular block, and is vertical in this illustration.
Turn the illustration in your mind, clockwise to the right.
Processor to the top, Ram Memory to the right, PCI slots (White) to the bottom.
The way it sits in your computer.
The Front Panel header now sits horizontal, and is parallel to the bottom edge of the motherboard.
There are 16 pins in the Front Panel header.
8 across the Top, and 8 across the Bottom.
The pins on Top are numbered ODD.
Starting at the Right side, (Closest to the CMOS Battery), going towards the Left, on the Top row;
Pins 1, 3, 5, 7, 9, 11, 13, and 15.
Starting at the Right side going towards the Left, on the Bottom row;
Pins 2, 4, 6, 8, a space, pin 12, a space, and pin 16.
There is NO pin 10, or 14. Just a space where these two pins would be.
A) Pins 1 and 3 are for the HarDDrive Activity LED light.
(HDD LED)
Pin 1 is for the Positive wire.
If the HDD LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pins 9, 11, 13, and 15 are NC. Not Connected.
D) Pins 2 and 4 are for the Power On LED light.
E) Pins 6 and 8 are for the Power On switch.
F) Pins 12 and 16 are NC. Not Connected.
For additional questions please post in a Comment. (Believe upper right of your page - Comment)
Regards,
joecoolvette
Sep 29, 2011 | Intel D845PT (KD845PTPAK10) Motherboard
I am having trouble figuring out the control panel jumpers
Hi, here is a few pictures of controlpanel connections.
Hope this will help you.
Apr 11, 2011 | Intel Desktop Board D845PT Motherboard
Instructions on connection led power and hdd led
go there
http://www.foxconnsupport.com/download.aspx?models=&category=C000000001&series=&keywords=650m02
Get the manual and download it on the desktop.
Open the manual with adobe reader.
On page 21 is the instruction
Jun 10, 2010 | Foxconn 650M02-G-6L Motherboard
Wiring problem
Usually the wire which has to be connected to motherboard would the purpose written on it.The motherboard also has the pin for the wire to be connected the pins are located near the IDE controller on the motherboard and the names usually be written next to the pin so all you need to do is to read and match each connection.
May 19, 2010 | Shuttle MV43N Motherboard
USB 2.0 on Intel D845PT Motherboard
HI,
Yes, that board is only a 1.1 USB port. USB 2.0 can easily be added to a computer using a USB 2.0 PCI card. These cards are relatively cheap and they can be found in almost any computer store. You can even find USB 2.0 PCI cards at Walmart. The cards will typically have 3 - 5 ports on them. These ports are setup so that you will have to plug your USB devices into the back of the computer.
Good Luck
Mark
Dec 28, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
USB 2.0 on D845PT
Hi Again,
I guess you posted your question twice, but just in case, here's the same solution:
Good Luck
Mark
Need original bios
you should enter your motherboard manufacture website and dawanload new version
Jan 12, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
Bios hangs
Reseat all cards in system, including the RAM. If it still does not boot try removing one stick of ram at a time to see if it boots. As well as removing extra cards.
Jan 05, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
Open Questions:
Online Cloud Backup And Online Backup - Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jun 19, 2018 | Quantum Computers & Internet
Cloud Backup For Small Business 'Dataalign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Cloud Backup For Small Business technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Online Backup Pricing is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Server Cloud Backup Solution up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Computers & Internet Logo
David Payne
David Payne
