My Kenmore elite heavy duty king size quiet pak II Top Load washer stopped in the middle of the wash cycle and began to give off a burning rubber smell( I think it overheated). I turned it off and removed plug. It would not start again or drain after letting it cool over night. Sounds like I had over loaded it and the coupler is broken. What I don't understand is why I can't get it to empty (drain)on the spin cycle. Is that normal or is there a possibility the pump is bad as well.
    President:
  • 1,654 Answers
The pump is connected to the same drive that drives the tub, if the coupling is bad then the pump won't work. Does the motor start and try to run? Do you hear a grinding sound when you start the motor? If so then I would suspect the coupling is bad. this is not an expensive repair, should be right arond $100.00 to replace the coupling and you migt want to get the agitator tabs replaced as well since they wear out about the same time as the coupling. This will only add about $10.00 to the repair. The drum has to spin to pump the water out!
Posted on Nov 14, 2010
Motor on kenmore elite washer quiet pak ii heavy duty capacity king size wont engage, just hums. and ideas?
Sounds like you motor coupling is gone this happens when over fill washer or place carpets/ bed blankets
Feb 15, 2015 | Kenmore Washing Machines
No heat
I can be several things, but most common is a burned out heating element. This can be tested with an Ohm meter.
Mar 15, 2014 | Kenmore Dryers
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
I also need the answer...
Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Kenmore 22422 Top Load Washer
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
May 16, 2017 | Kenmore 22642 Top Load Washer
Washing Machines Logo
173 people viewed this question
Top Washing Machines Experts
