Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Lg lrfd22850sw frige code says ER FF. what does it mean! Please HELP!!!
I don't hear the fan any more could that be the problem? PANEL SHOWING ERROR CODE OF IF
  • Anonymous Sep 18, 2008
    I had this same problem. I reset the code by turning the electricity off and on and it worked for one month. Now I have the same problem. I do think it is the fan getting frosted up. This seems to be a problem with the refrigerator. I wonder if others aren't having this same problem.
  • Anonymous Mar 22, 2014
    Error ER FF on the panel and some noise from the Fridge
I had the same error code. The problem was that the fan had frozen. I defrosted the fridge/freezer completely (it was ok for me cause I have a spare fridge). Your problem possibly is a frozen fan problem
Posted on Jun 26, 2008
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Refrigerator displaying error "ER FF".
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue.
This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
The door panel says "Er FF" and now it is not cooling
Er FF - Freezer Fan Error - This can be caused by frost accumulation on or around the freezer fan. Unplug the unit for 3-4 hours to allow this to melt off. If error code persists, call Customer Service.
Oct 30, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerator LG LFC25760ST Serial # 701KRUC00022 PROBLEM ERROR CODE: ER FF What is this? How can I solve the problem?
Hi, The FF error code indicates that the freezer fan motor is defective. You could also get this code if ice is preventing the fan from turning. Please set up service for refrigerator before the fan motor gets worse !
It's written like this in the repair manual:
Which means what I just wrote above about the fan motor!!
Error detection category:
Abnormality of BLDC FAN Motor for Mechanic Room
Error Display: FF
Error generation factors:
It is caused when F/B signal isn’t over 115 seconds during BLDC FAN motor operating
Remarks:
Poor BLDC Motor connection, DRIVE IC, and TR.You can check the below trick, if that might work on your model :-
Pull the top and bottom baskets out, and take the back panel out from inside. There would be asolid block of ice built up around both fans and wires. Take a blow dryer and gradually melt the ice around the fans and wires. Then, pull the remaining ice chunks off of the wires. Then put the thing back together and it should clear the message.
Unless call a tech from LG.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 12, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
What does message: Er FF mean?
That means the freezer fan is blocked, you need to order a new High voltage board, the ice has built up enough from not defrosting that it is interfering with the operation of the evaporator fan.
Jun 22, 2009 | Refrigerators
LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Jan 25, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
Error code ER FF
The error indicates the freezer fan is not functioning properly. The fan supplies cold air to the refrigerator that is why it seems warmer.
The fan may be frozen, try unplugging it for a few hours to let it thaw. Also check to see if something may have gotten into the vent holes in the freezer that could be blocking the fan from turning.
Mar 11, 2008 | Refrigerators
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
477 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
