I have sony Vaio VGN-CS36GJ - Recently i was trying to restore it to factory settings via Vaio recovery due to virus attach but suddenly it didn't either recovered to factory setting but looks as operating system is corrupted. I am not able to recover it with F10 on start up as it gives blank corrupted window and also sysatem is not reading my recovery disc 2. may be some problwm with disc. how can i recover OS back on my machine. when i run recovery disc 1, i can reach till comapnd prompt and can see the recovery partition exists but C: drive is formatted. Is there any way to execute partition drive from command prompt or any other way to recover OS on machine. any help will be much appreciated
    Brigadier General:
  • 8,909 Answers
I would have recomended Norton Antivirus or a full programme anti virus to clean your drive. However, it is almost too late for repairs.
You need to format your drive but as there seems to be a "Worm" type virus, I guess due to the problems you are having trying to re install OS, it will keep reinfecting the drive due to it being resident in the memory.
You really need an antivirus programme to clean your Sony Vaio before you can succesfully place an uninfected OS on your drive. I hope the recovery partion is not infected as well, a good anti virus programme will clean it though. When it is clean, boot with a system disk with the same OS on it and when you get to drive "C" hopefully drive "D" will be available, assuming "D" is the recovery drive partition.
When you get your anti virus disk, you will need it to be a bootable disk with the format command on it. When it has been cleaned you can then format the disk and put your recovery OS disk back on.
Hope this helps.
Posted on Nov 13, 2010
Sony VAIO VGN-NS140E/PC. No recovery disk and need to set back to factory settings.
Go to system restore most newer laptops have a section on the hard drive for resetting back to factory defaults
Oct 21, 2013 | Sony VAIO VGN-CR507E/PC Laptop
Restore factor settings on sony vaio VGN-NS110E
Click the Windows "Start" menu.
2-Click the "Help and Support."
3-Select the "Vaio Recovery Wizard" option.
  • 4-The Vaio Recovery Wizard will launch. Follow the instructions given as you advance through the wizard. When prompted, confirm that you want to reset your Vaio to its original factory settings.
  • 5-Allow the computer about an hour to properly restore itself to factory settings.
  • Apr 11, 2012 | Sony VAIO VGN-NS110E/L Notebook PC
    Where is reset button of sony vaio vgn-b100b?
    Unfortunately, there is no reset button in this model. If you want to restore the factory settings in the computer, please perform a system recovery using the recovery partition or the recovery discs.
    Thanks!!!!
    Dec 24, 2010 | Sony VAIO VGN-B100B Notebook
    Computer crash. Have No recovery disk.
    Hi jgar2141,
    If you are trying to restore the Computer to the factory settings, it is not required to have the Recovery Discs as you can use the Recovery Partition which is present in the hidden partition of the Hard Drive. To access the Recovery Partition, restart the Computer, press and hold the F10 Key for 7 to 10 seconds. This will boot the Computer to the Edit Boot Options screen. There, please press the Enter Key.This will launch the VAIO Recovery Center. In the VAIO Recovery Center window, you can select the "Restore C: Drive" option to restore the Computer to the factory settings. (Selecting the "Restore C: Drive" option will erase all the Data in the Computer and restore to the factory defaults)
    After selecting the Restore C: Drive, please follow the simple onscreen instructions to proceed with the System Recovery. The System Recovery process using the VAIO Recovery Center should fix all the Software issues in the Computer and restore the Computer to the factory defaults.
    Good Luck!
    Please post back if you have any questions or require any further assistance.
    Thanks for using FixYa.
    Nov 10, 2010 | Sony VAIO VGN-CR507E/PC Laptop
    My sony vaio VGN-CS22GH laptop shuts doen by itself randomly. Please help
    The issue may be due to any recent hardwrae or software changes and also due to any virus.
    1. Remove any recently added hardware/software.
    2. Try to boot the computer in safe mode. Press F8 button soon after restarting the computer to enter the advance boot option and select safe mode to boot computer in safe mode.
    3. If issue persists even in safe mode, perform a system restore to an earlier time or date when the computer was working as expected. Performing system restore will not delete any data from the computer.
    4. Reset BIOS to default values. (Press the F2 key after restarting the computer to enter and access BIOS).
    5. Press F3 and F4 keys to reset the BIOS. or press the right arrow key until you reach the exit menu, then select the load BIOS default option.
    6. Then, select the Yes option when promted, save the settings and select yes option. restart computer and check.
    7. If still persists, perform a system recovery using the VAIO Care Software or the F10 recovery partition.
    Note: ensure to backup any important data before perfoming system recovery. System recovery will erase all the data presnt in the computer.
    Nov 07, 2010 | Sony VAIO Notebook
    VAIO VGN-FS742/W PC Notebook: i need to know how to restore factory settings wit...
    This Computer has Recovery Partition hidden in the Hard Drive. You can access the Recovery Partition using the VAIO Recovery Wizard or pressing the F10 Key while restarting the Computer.
    The System Recovery will restore the Computer back to the factory defaults and all the data in the Computer will be lost.
    1. To access the VAIO Recovery Wizard, please click "Start", All Programs" , VAIO Recovery and VAIO Recovery icon.
    2. Then, in the VAIO Recovery Window, please select the "Restore C: Drive" option.
    3. Then, in the Restore C: Drive window, click to select the I understand box.
    4. Then, click the Next button.
    5. After the bundled applications are installed, under Restore C: Drive (Step 4 of 4) , click the Finish button.
    6. The computer will restart and the operating system setup wizard will begin.
    7. Please follow the on-screen instructions to complete the setup wizard.
    Good luck..
    Thanks for using Fixya.
    May 18, 2010 | Sony VAIO VGN-FS742/W Notebook
    Want to reset Sony VGN-NR160E/s Vaio NB to factory
    Just power on your laptop and keep pressing F10 key. You will get one wizard to restore your laptop to factory settings.
    iTechGuru
    www.itechguru.in
    Mar 29, 2010 | Sony Computers & Internet
    MY laptop is asking for recovery disks, but I forgot to make them, now I can't get it to come on it's a Sony Vaio VGN-SZ4XWN/C
    hold f10 when the vaio/phoenix/intel boot screen appears. this will take you to the vaio recovery center, where you can restore the computer to original factory settings.
    Oct 24, 2009 | Sony VAIO SZ Series Notebook VGN-SZ780EB
    Can't restore factory intallations and settings: Vaio VGN-FE880E
    Are you doing DESTRUCTIVE recoveries or are you doing NONDESTRUCTIVE recoveries? Try another hard drive in the machine and recover to that. Nondestructive recoveries replace the operating system without destroying the personal data. Its possible the original problem is propagating over to the recovered systems. Do a destructive recovery. Understand any data not backed up will be destroyed. Possible the original problem was a trojan virus.
    Mar 23, 2009 | Sony VAIO VGN-FE880E/H Notebook
    Sony notebook, restore to factory settings without cd
    scan your computer with avast antivirus.update it .
    http://www.scanwith.com/download/avast_Home_Edition.htm
    download from here
    then scan in safe mode or boot time
    Feb 07, 2009 | Sony VAIO VGN-FS980 Notebook
    Computers & Internet Logo
    503 people viewed this question
    David Payne
    David Payne
